    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Autocad Splines
    4 Posts 3 Posters 961 Views 3 Watching
    • G Offline
      grdnblak
      Does anyone know why when an autocad(2007) drawing is imported in to SU6, the splines disappear when a style is applied? is there any way to fix this?
      It's not what you know, it's who you know
      • Chris FullmerC Offline
        That sounds more like a bug. Is this repeatable? Could you post a cad file that we could import and test? If it is something that can be repeated we can pass it on to to the SU development team as a bug. Thanks,
        All my Plugins I've written
          Just a guess but are the line segments in the imported spline very short? It could be that they are shorter than the shortest line segment in the style. Or short enough that with Halo enabled in the style (if that is the case) that no line segments are displayed. It happens on small or high-segment circles and arcs sometimes. too.
          • G Offline
            grdnblak
            Apologies the for the delay in the response. Think you may be right Dave. There were a few splines within the drawing that contained varying amount of segments. It appears that those that had many short segments were the ones that did not show within the styles. On running the 'weld' script on the splines to make them one polyline in SU, they appear in the style, thanks Dave! πŸ‘
