    Mitering Molding
    8 Posts 3 Posters 1.4k Views 3 Watching
    • R
      Rob46
      Hello everyone,
      Just found this forum. I've been playing around with SU for a little while. I'm drawing a book case with cove molding around the top. I have the molding drawn and placed on the bookcase but can't figure out how to bring the corners together like a miter joint. Anybody have any ideas?
      Rob
      • D
        dylan
        Rob are you wanting to take the moulding around three sides?
        It sounds like you need to use Follow Me.
        Place the moulding on a corner (your start point) select the three lines you require the profile to follow - Choose follow me and pick the moulding.
        If this is what you need I would be happy to create a quick tutorial for you to follow if the above does not seem to make sense.
        http://dmdarchitecture.co.uk/
        • R
          Rob46
          Dylan,
          Thanks for the quick response. I just tried what you suggested and it worked πŸ˜„ . Thanks a lot.
          Rob
          • R
            Rob46
            Dylan
            I thought it worked but I can only get the molding to go around 1 corner. Still need it on the other side. If it's not too much trouble a tutorial might be helpful. Thanks
            Rob
            • W
              watkins
              I suggest you go here:
              Regards,
              Bob
              • R
                Rob46
                Thanks Bob. That clears things up and I see what I was doing wrong.
                • W
                  watkins
                  Dear Rob46,
                  My pleasure, and I also learned a new trick with the Alt key too.
                  Regards,
                  Bob
                  • D
                    dylan
                    That is a really good video explaining Follow Me, thanks for the link Bob.
