    Mitering Molding
    8 Posts 3 Posters 1.3k Views 3 Watching
      Rob46
      Hello everyone,
      Just found this forum. I've been playing around with SU for a little while. I'm drawing a book case with cove molding around the top. I have the molding drawn and placed on the bookcase but can't figure out how to bring the corners together like a miter joint. Anybody have any ideas?
      Rob
        dylan
        Rob are you wanting to take the moulding around three sides?
        It sounds like you need to use Follow Me.
        Place the moulding on a corner (your start point) select the three lines you require the profile to follow - Choose follow me and pick the moulding.
        If this is what you need I would be happy to create a quick tutorial for you to follow if the above does not seem to make sense.
        http://dmdarchitecture.co.uk/
          Rob46
          Dylan,
          Thanks for the quick response. I just tried what you suggested and it worked πŸ˜„ . Thanks a lot.
          Rob
            Rob46
            Dylan
            I thought it worked but I can only get the molding to go around 1 corner. Still need it on the other side. If it's not too much trouble a tutorial might be helpful. Thanks
            Rob
            • W Offline
              watkins
              I suggest you go here:
              Regards,
              Bob
                Rob46
                Thanks Bob. That clears things up and I see what I was doing wrong.
                • W Offline
                  watkins
                  Dear Rob46,
                  My pleasure, and I also learned a new trick with the Alt key too.
                  Regards,
                  Bob
                    dylan
                    That is a really good video explaining Follow Me, thanks for the link Bob.
