    Style Stroke
    2 Posts 2 Posters 929 Views 2 Watching
    • A
      awillard
      I am new to the board, but have read several posts. I have a question about styles. How come some styles have a stroke setting under the edge setting options and some don’t? How do you change it on the ones that have that option? Thanks in advance.
      Aaron Willard
      • GaieusG
        Hi Aaron,
        To tell the truth I'm not a style wizard but my opinion is that when a style uses vector based lines it doesn't have a stroke setting while the ones using raster based lines have this setting (since they need these raster images to be defined).
        You can "mix" styles in the style dialogue or - if you have a Pro license - you can use Style Builder to create your custom styles.
        I'm moving this topic from the Tutorials forum since it is not a tutorial.
        Also, read about the basic concepts of styles by Ross here. It will explain things more deeply than my puny answer above.
