    Style Stroke
    2 Posts 2 Posters 916 Views 2 Watching
      awillard
      I am new to the board, but have read several posts. I have a question about styles. How come some styles have a stroke setting under the edge setting options and some don’t? How do you change it on the ones that have that option? Thanks in advance.
      Aaron Willard
        Hi Aaron,
        To tell the truth I'm not a style wizard but my opinion is that when a style uses vector based lines it doesn't have a stroke setting while the ones using raster based lines have this setting (since they need these raster images to be defined).
        You can "mix" styles in the style dialogue or - if you have a Pro license - you can use Style Builder to create your custom styles.
        I'm moving this topic from the Tutorials forum since it is not a tutorial.
        Also, read about the basic concepts of styles by Ross here. It will explain things more deeply than my puny answer above.
