Hidden lines problem
I have been trying to open a Skp plan in Turbocad and having trouble with the hidden lines. The Skp file opens fine with all the layers in tact, but the hidden lines are showing up visible with no way to turn them off. I also tried a dwg export of the plan, which resulted with the same. Is there some type of work around to place the "hidden lines" on a separate layer so they might be controlled or has anyone found another way to work around this problem?
Thanks Kevin
Have you tried the soften/smooth edges tool?
in the menu, go to window>soften edges. Select the hidden lines and try to move the arrow in the s/s.e. window tool. -
Yes I have already softened the edges in Skp. The problem seems to be that hidden edges or lines, while they appear hidden in Sketchup, are not hidden once opened in Turbocad. In an ideal world the best solution would be to have the ability to place the hidden lines on a separate layer and turn them off. Once the model is opened in another program, it takes a lot of time to remove the hidden lines manually, which are not necessary for construction documents. I wonder what the autocad users are doing with this problem.
Thanks Kevin
### A Ruby script can easily do this... model=Sketchup.active_model;hidn=model.layers.add("HIDN");model.entities.each{|e|e.layer=hidn if e.hidden?} ### Copy the whole of the line from 'model=...' to '...?}' and paste it into the ruby console to see what it does. ### Feel free to add a menu entry etc and make it run that way if desired... ### To do 'soft' edges rather than 'hidden' ones then the 'e.hidden?' becomes 'e.soft?'... -
TIG that's a little over my head as I haven't used the Ruby scripts. Wish I understood them better.
Thanks anyway
Kevin -
TIG thanks, I will give it a try and report back with my results. I may have to ask more questions if I have a problem. This would be great if I can make it happen. It's late for me now, but I will do it in the morning.
Kevin
Don't be scared...
You don't need to understand how a car works to drive it ! Just paste the line and it does what you want...
Let's say you have your model ready to export to DWG.
Let's make a copy of it to be on the safe side...
Open the Ruby console and copy/paste in that line I just gave you.
It then runs and does exactly what it says...
It makes a new layer called HIDN.
It goes through all of the entities in the model.
IF they are hidden it puts them onto that layer.Done.
You now have all of your hidden things on their own layer.
Export it to DWG.
In the DWG in AutoCAD 'freeze' the layer called HIDN and you don't see those hidden lines any more...Try it - it's easier to do than it is to explain...
TIG you were right, I didn't have a lot of trouble loading the script, but it doesn't seem to control turning off the hidden lines. I did a test anyway and exported to Turbcad using dwg and the hidden lines were still there, even though there is a separate layer for them. Hmmm! Have I done something wrong?
Thanks Kevin
No, Kevin, I guess that's what TIG's script should do. Put the hidden lines onto a separate layer. But now at least you can turn the visibility of that layer off so the hidden lines won't show.
Thanks Gai.
The ruby code makes a layer and puts the hidden things onto it. In CAD you can switch that layer off [or 'freeze' it] so they aren't seen...
To hide hidden things in SUp toggle view geometry on/off.
Gai I see what I missed. All of the "hidden geometry" that needs to be made invisible must still be selected and placed on the new HIDN layer manually. Of course that makes sense now. I mistakenly thought the ruby script was picking up the info (geometry) from Sketchup. The script TIG made for me works perfectly. This helps alot.
Thanks TIG and Gai
Kevin
You should NOT need to manually pick hidden geometry ! The whole object of the script was to move everything over onto that layer automatically...
It does - BUT only 'loose geometry' is processed as it does 'entities'. If you want to do Groups and Component definitions the codes a bit different... 'active_entities' - so it processes their entities within an 'Edit' session, when it's run.model=Sketchup.active_model;hidn=model.layers.add("HIDN");model.active_entities.each{|e|e.layer=hidn if e.hidden?}I've posted a short script version in the Ruby forum - here it is: http://www.sketchucation.com/forums/scf/viewtopic.php?p=47500#p47500
Then all you have to do is put it into your Plugins folder and pick the menu item under Plugins called 'Hidden to Layer'...
TIG somehow it still isn't working for me. Pictures below show simple extruded molding profile with the HIDN unchecked, but the hidden lines are still there. The second picture is a dwg file opened in Turbocad with the same result. What might I have done wrong? The molding is not a group.
Thanks Kevin
Can you post a bit of the file. Just that moulding'll do so I can look at it... Works for me with geomentry, groups and definitions...
TIG here is a skp. file with a piece or the molding along with a dwg created from skp. The script created a layer named HIDN ok, but I had to select the hidden lines manually to place on that layer.
Thanks Kevin
The 3D export function to DWG exports the SU faces as 3D polyface entities, with every face as a separate entity. If you check "Edges" in the Export Options every edge in the model is added as an extra line in the export. It does apparently not support smoothing.
I don't know about TurboCad, but in AutoCad wireframe and hidden-line views the edges of polyface entities are always visible and unseparable from the faces themselves. For smoothing to work, the export would have to consist of a triangulated 3D face mesh
If you are exporting views for annotation and plotting, you can export 2D DWGs - no hidden lines pop up with them.
Anssi
Your edges weren't just hidden but softened and smoothed. I've re-done the script to do that too, BUT the problem is that when you Export to DWG all hidden/softened/smoothed edges also export as Layer0 edges - I assume to keep the faces they have they need to be on a layer... It seems you can hide such edges in various view styles in CAD, BUT only the hidden things seem to move en mass...
I'll do some more investigating and post an updated script shortly...
Annsi, your observations are what I had noticed concerning the 3ds export and triangulated faces are fairly useless for views for annotations and plotting. I was trying to avoid so many exports/imports using the 2d dwg's. Ideally, if the hidden lines could be controlled (turned on and off) for export using a dwg/dxf, using outside Cad programs for the layout and plotting would be nice. I have not found this part of the process to be that great using Skp.
Thanks TIG
Kevin
http://www.sketchucation.com/forums/scf/viewtopic.php?p=47503#p47503 is the v1.1 file...
This also moves hidden + soft + smoothed edges onto layer HIDN and switches the layer off.However, it's proved a little useless since the exporter to DWG/DXF makes any edges to faces on the same layer = Layer0 if that's what the face or other edges are on... SO whilst you get the 'hidden' edges etc on their own layer you also get duplicates on Layer0 !!!
Register LoginAdvertisement
