Missing Lines
When I print or create a jpeg of a SU 2d dwg some of the intricate detaials / lines are missing. Does anyone have a solution?LO AHD ttlblk.layout
It is a feature of the "Sketchy edges" style that you are using. Smaller details fade away the farther they are from the camera. Your mullions became visible when I moved the "level of detail" slider in the Style Edit window to the far right. The fading cannot be turned off altogether, so if that is not enough, the only option is to switch to a non-sketchy style.
Anssi
Register LoginAdvertisement
