    [Plugin] Auto Centerpoint
    41 Posts 13 Posters 35.4k Views 13 Watching
      Jim
      New version is available here:
      Plugin: Auto CenterPoint
      Auto Centerpoint automatically adds a centerpoint to circles, arcs, and polygons. Update Sep 2011 - This is an older plugin and not well...
      (sketchuptips.blogspot.com)
      Let me know how it works for you.
      • jujuJ Offline
        juju
        Error Loading File auto_centerpoint.rb
        No such file to load -- ruby/singleton
          Jim
          OK, should be fixed. You'll need to download again from the same link and try again. Sorry.
          • O Offline
            outersketcher
            Jim,
            As a newbie at sketchup, I was excited to find this ruby script.
            The script seems to have installed ok since I do get the little single button menu.
            But, how do I use it? I've tried clicking on it first to activate the ruby... but when I use the circle tool... I don't see any center point. And I've tried creating the circle first, and then clicking on the auto center button and then back to the circle again... neither method works. Am I not doing something right?
            I am running sketchup 6 on an intel-based mac running system 10.5.2.
            Thanks,
            outersketcher
            "I mostly enjoy not being dead.." -Grandpa
              Jim
              I just downloaded it and reinstalled it, and it works. You should have the following files and folders in your Plugins folder:acp.jpg
              Then, you can toggle the creation using the toolbar button.
              One other thing - points aren't created until you switch tools.
              • O Offline
                outersketcher
                Well, bummer...still can't get it to work yet.
                I've double checked the plugins folder and the two folders and file are there.
                The plugin button appears and responds to my mouse by going darker when I click on it... but, nothing else happens when I draw the shape and click to a different tool.
                This might be a Mac thing? Are there any other Mac users using this ruby okay?
                David
                  Jim
                  It could be a Mac thing - I don't have a way to test on a Mac. However, it should work on both platforms. Can someone try this on a Mac?
                  • david_hD Offline
                    david_h
                    I am getting the same message. Im on a PC. I however did not get the RUBY file in my Plugins directory that was shown in the little graphic above.
                    [/quote]
                    OK, should be fixed. You'll need to download again from the same link and try again. Sorry.[/quote]
                      Jim
                      Make sure when you extract the .zip file, the folder structure is maintained.
                      • placidfuryP Offline
                        placidfury
                        I'm getting the ruby/singleton error as well... have re-downloaded, dir structure is there... any ideas? Thanks!
                          Jim
                          The folders should be set up like this:
                          Plugins/
                              AutoCenterPoint/
                                  autocp.rb
                              ruby/
                                  singleton.rb
                            placidfury
                            I guess that's the problem, because the zip file I downloaded (both times) has no singleton.rb file or a ruby subdirectory... the other files are there, and properly in their subdirs... but that one is missing altogether... do you see it when you open it?
                              Jim
                              Wow, I'm very sorry. I thought I checked that .zip file; twice. You are correct - it does not have the ruby/singleton.rb file. 😳
                              Here is the correct download.
                              http://sites.google.com/site/jimfoltzllc/plugins/automatic-centerpoints/auto_centerpoint.zip?attredirects=0
                                placidfury
                                Thanks! This will rock... I've done so many models with curves lately, and having this autocenterpoint script will sooooooo simplify my work. You rock!
                                  Jim
                                  Has any one who uses this plugin had any stability issues? I've had a report and was able to repeat the issue, but I am curious if anyone else has had any issues with it?
                                  • Bob JamesB Offline
                                    Bob James
                                    Using this URL gives an error, "Site Not Found"
                                    • TIGT Online
                                      I have included auto Arc and Circle Cpoints in my 2D tools...
                                        Jim
                                        It sounds like the 2D tools are improving all the time. I have an endless number of ideas if you're ever bored. πŸ˜„
                                        I think Auto Centerpoint is a little different. It is able to detect objects with center-points as they are drawn using the built-in tools - Circle, Arc, and Polygon. But also when the modification tools are used - Move, Rotate, Scale, Pushpull, Offset, and also when pasting geometry, and when using any Ruby tool that creates an ArcCurve (such as 2D tools.)
                                          Jim
                                          It's currently here, but I wouldn't recommend this version: http://sketchuptips.blogspot.com/2008/03/plugin-auto-centerpoint.html
                                          I am working on an update.
                                            Bob James
                                            Jim,
                                            Seems to work just fine.
                                            Point of interest: It only works if loaded into the HD/Users/Username/Library/...... instead of the usual HD/Library/.....
                                            • 2 / 3
