    [Plugin] Auto Centerpoint
    41 Posts 13 Posters 36.4k Views 13 Watching
    • placidfuryP Offline
      placidfury
      I'm getting the ruby/singleton error as well... have re-downloaded, dir structure is there... any ideas? Thanks!
        Jim
        The folders should be set up like this:
        Plugins/
            AutoCenterPoint/
                autocp.rb
            ruby/
                singleton.rb
          placidfury
          I guess that's the problem, because the zip file I downloaded (both times) has no singleton.rb file or a ruby subdirectory... the other files are there, and properly in their subdirs... but that one is missing altogether... do you see it when you open it?
            Jim
            Wow, I'm very sorry. I thought I checked that .zip file; twice. You are correct - it does not have the ruby/singleton.rb file. 😳
            Here is the correct download.
            Error 404 (Not Found)!!1
            (sites.google.com)
              placidfury
              Thanks! This will rock... I've done so many models with curves lately, and having this autocenterpoint script will sooooooo simplify my work. You rock!
                Jim
                Has any one who uses this plugin had any stability issues? I've had a report and was able to repeat the issue, but I am curious if anyone else has had any issues with it?
                • Bob JamesB Offline
                  Bob James
                  (sites.google.com)
                  Using this URL gives an error, "Site Not Found"
                    I have included auto Arc and Circle Cpoints in my 2D tools...
                      Jim
                      It sounds like the 2D tools are improving all the time. I have an endless number of ideas if you're ever bored. πŸ˜„
                      I think Auto Centerpoint is a little different. It is able to detect objects with center-points as they are drawn using the built-in tools - Circle, Arc, and Polygon. But also when the modification tools are used - Move, Rotate, Scale, Pushpull, Offset, and also when pasting geometry, and when using any Ruby tool that creates an ArcCurve (such as 2D tools.)
                        Jim
                        (sites.google.com)
                        It's currently here, but I wouldn't recommend this version: http://sketchuptips.blogspot.com/2008/03/plugin-auto-centerpoint.html
                        I am working on an update.
                          Bob James
                          Jim,
                          Seems to work just fine.
                          Point of interest: It only works if loaded into the HD/Users/Username/Library/...... instead of the usual HD/Library/.....
                          • john2J Offline
                            john2
                            on jim's website upon clicking the plugin download link i'm getting this 😞
                            Page not found
                            We're sorry, but we were unable to locate the page you requested.
                            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                            • 2 / 3
