    [Plugin] MatrixProximity Update v1.9 20110708
    40 Posts 9 Posters 30.8k Views 9 Watching
      GreyHead has pointed out a glitch in the MatrixProximity 'swapping similar components' method.
      This fixes the problem with it finding the right directory - caused by changes to the way Ruby 'now' returns the FindFile path with/without a / at the end of a directory... [actually it changed ages ago, but I never caught it...]
      This version and some further improvements and fixes...
      AND the missing menu issue fixed!
        chango70
        Superbly useful tool! Thanks so much! 😍
          Bertier
          how does that work ?
            What work?
            Read the Guide PDF... 😕
              Thanks Pilou... I was just getting a link 😉
                You can find the doc here 😉
                  Bertier
                  No pdf attached to the download...
                  I have it from a previous download.
                      Bertier
                      thank you
                        Bertier
                        I don't get it...
                        Pilou tu peux m'aider... ?
                          Bertier
                          sorry TIG
                          I really don't understand how to use your plugin....
                          I have the same statue in 3 LOD
                          name is :
                          statue-001+
                          statue-001~
                          statue-001-
                          run the plugin
                          see the boxes
                          nothing happens on screen !
                            Are those +/~/- components loaded into the SKP, or at least available in the '../Proximity Components' folder that you need to add inside the '../Components' folder?
                            The script is pretty old and also quite ropey!
                            I can fix it if you really want!!
                            What is it you want to do exactly ??
                              Bertier
                              Sorry TIG I missed that part : create a proximity folder....
                              I'll try that now
                              I'am trying to draw a perspective 300 m long with a statue evry 10 m
                              the one in the far don't need high res
                              I want to create scenes and not re-load manually every component ...
                              screen shot
                                Bertier
                                can't mak work 😞
                                  You need to set a range in the dialog so that some statues fall outside the limit and are thereby made the '-' type. I assume that the three types are made with the same origin and overall dimensions BUT the farther ones are less complex forms ?
                                  Do you want to PM me the three types and I'll see what's what... 😕
                                    Bertier
                                    thank you TIG...
                                    I how [owe?] you some pints.
                                      @Bertier
                                      You can use the Random Replacement of a Composant by Sdmitch 😉
                                      Just take one composant as source for avoid the random if neeeding 😉
                                      And despite of that in case of Big Size component (polys) use the Ghost component by fredo 6 😉
                                        Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=46802#p46802
                                        I've made some additional fixes to the code to bring it up to date...
                                          Bertier
                                          thank you I'll try tonight
                                          • EarthMoverE Offline
                                            EarthMover
                                            Where can I find the original .zip file for this? I've never used this before so I think I'm lacking a few things to make it work. I tried to just drop in the .rb file and create the subfolder in my components folder, but I can't get it to show up in the plugins list. Perhaps it would be helpful to repackage it with everything needed to make it work.
                                            Thanks TIG, this looks useful.
                                            Content Creator at Skapeup
                                            • 1 / 2
