    [Plugin] MatrixProximity Update v1.9 20110708
    40 Posts 9 Posters 32.0k Views 9 Watching
    • B
      Bertier
      I don't get it...
      Pilou tu peux m'aider... ?
      • B
        Bertier
        sorry TIG
        I really don't understand how to use your plugin....
        I have the same statue in 3 LOD
        name is :
        statue-001+
        statue-001~
        statue-001-
        run the plugin
        see the boxes
        nothing happens on screen !
          Are those +/~/- components loaded into the SKP, or at least available in the '../Proximity Components' folder that you need to add inside the '../Components' folder?
          The script is pretty old and also quite ropey!
          I can fix it if you really want!!
          What is it you want to do exactly ??
          • B
            Bertier
            Sorry TIG I missed that part : create a proximity folder....
            I'll try that now
            I'am trying to draw a perspective 300 m long with a statue evry 10 m
            the one in the far don't need high res
            I want to create scenes and not re-load manually every component ...
            screen shot
            • B
              Bertier
              can't mak work 😞
                You need to set a range in the dialog so that some statues fall outside the limit and are thereby made the '-' type. I assume that the three types are made with the same origin and overall dimensions BUT the farther ones are less complex forms ?
                Do you want to PM me the three types and I'll see what's what... 😕
                • B
                  Bertier
                  thank you TIG...
                  I how [owe?] you some pints.
                    @Bertier
                    You can use the Random Replacement of a Composant by Sdmitch 😉
                    Just take one composant as source for avoid the random if neeeding 😉
                    And despite of that in case of Big Size component (polys) use the Ghost component by fredo 6 😉
                      Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=46802#p46802
                      I've made some additional fixes to the code to bring it up to date...
                      • B
                        Bertier
                        thank you I'll try tonight
                        • EarthMoverE
                          EarthMover
                          Where can I find the original .zip file for this? I've never used this before so I think I'm lacking a few things to make it work. I tried to just drop in the .rb file and create the subfolder in my components folder, but I can't get it to show up in the plugins list. Perhaps it would be helpful to repackage it with everything needed to make it work.
                          Thanks TIG, this looks useful.
                          Content Creator at Skapeup
                            Here's an updated version that fixes the 'missing menu issue'! 😳 Sorry! http://forums.sketchucation.com/viewtopic.php?p=46802#p46802
                            Here's the guide MatrixProximityGuide.pdf
                            All you need for 'Proximity' to run is a folder called 'Proximity Components' in the main 'Components' folder, useful IF you haven't already loaded a 'set' of three 'proximity components' [ending in +/~/-] into your model...
                            • B
                              Bertier
                              this is GREAT !
                              it's finally working !!!
                              here are some pics before / after :
                              edges go from : 1,492,371 --> 245,003 !!!
                              this is fantastic !
                              TIG YOU ROCK !!!!
                                'Proximity' was a tool that didn't develop much after I had the idea.
                                It relies on you using it manually at each change of view with you having made two or three components with more/less detail for near/mid/far way from the camera locations [same origin etc but less geometry]. Each with +/~/- on the end of their name or thier SKP if external components used in the 'Proximity Components' folder inside Components folder, IF the components are not already loaded into the current SKP...
                                I'd be interested in your feedback/ideas...
                                  Idea: Same but not from the camera but from a point x,y,z
                                  • B
                                    Bertier
                                    Hi TIG, thank you again for this, I believe it will be really helpfull into the projetc I am currently working on, and I imagine to other who handle large files with repeated components.
                                    • the : + / - extension make real sense as well as : ~, but for some reason on a French keyboard : ~ is not an easy "key"
                                    • when saving "statue-001+.skp" the "+" sign transforms in "statue-001_.skp", I then have to rename the file...
                                    • would it be possible to have script that auto-saves a component into -001+ / -001~ / -001- ? maybe combined with Polyreduce...
                                      a one-stop plugin from a component file --> +/~/-
                                      if so : just copy past fromt the text above 😉
                                        On an UK English keyboard a tilde ['~'] is just a shifted '#' sign? code= U007E
                                        On a FR keyboard isn't it the key to the left of the top line '1' key +shift ??
                                        or you should use the French keyboard shortcut = AltGr+é then a <space> [<then backspace> to remove the space!]- if there's no space it tries to put the tilde over the last typed character if it's an 'a' or 'e' etc ?
                                        On a FR Canadian keyboard I think it's Ctrl+Alt+; for the ~ ??
                                          Same as TIG describe: Alt Graphic + é twice then Backspace 😉
                                          Appuyer 2 fois sur é Alt Graphic étant appuyé : on obient curieusement 2 tildes (~~) puis Backspace pour en effacer un 😒
                                          • B
                                            Bertier
                                            salut Pilou sur mon clavier c'est : "Alt Gr + é" mais il faut le faire "é" fois et effacer une instance...
                                            comment c'est sur le tien ?
