TIG's Volume Calculator
Dear Tig,
I have been running your version 1.8 quite happily and was pleased that it coped with the attached model. However when I tried to use the latest version of your script it caused the program to hang.
For your information, I have attached both the model and the 'successful' script I am using.
Regards,
Bob
Dear Tig,
Have you had time to look at this, or should I just go on using version 1.8?
Kind regards,
Bob -
Still trying to fit it in... Meanwhile use the last 'good' version for you...
Dear TIG,
Many thanks for replying. It is a non-urgent request as your V1.8 seems to work fine and is accurate to the stated tolerances.
FYI, the model is that of a machine base that is to be cast from polymer concrete. The volume gives me the mass (density 2,300 kg/m^3), and an estimate of the cost.
Kind regards,
Bob
Register LoginAdvertisement
