    TIG's Volume Calculator
    4 Posts 2 Posters 706 Views 2 Watching
    • W Offline
      watkins
      Dear Tig,
      I have been running your version 1.8 quite happily and was pleased that it coped with the attached model. However when I tried to use the latest version of your script it caused the program to hang.
      For your information, I have attached both the model and the 'successful' script I am using.
      Regards,
      Bob
      Volume calculation_1.skp
      VolumeCalculator.rb
      • W Offline
        watkins
        Dear Tig,
        Have you had time to look at this, or should I just go on using version 1.8?
        Kind regards,
        Bob
          Still trying to fit it in... Meanwhile use the last 'good' version for you...
          • W Offline
            watkins
            Dear TIG,
            Many thanks for replying. It is a non-urgent request as your V1.8 seems to work fine and is accurate to the stated tolerances.
            FYI, the model is that of a machine base that is to be cast from polymer concrete. The volume gives me the mass (density 2,300 kg/m^3), and an estimate of the cost.
            Kind regards,
            Bob
