How do you Make Thin Lines?
Hello,
I thought this would be easy, but I don't see how to make the lines in the objects thin. They are thin when I move the object, but as soon as the object stops the lines change to thick, like going from pen to magic marker.
Is there a way to make and keep the lines thin?
Thank you.
Greg
Greg,
View: Edge style: Profiles unchecked?
I'm gonna guess you have "profile edges" selected: go into the "display settings" menu in SU5 (the "styles" menu, "edges" tab, in SU6) to check...?
Thanks Jim and tomsdesk. Unchecking 'Display Edges' does not do it because I'm using lines to simulate empty bins in a virtual warehouse, but setting the line profile from 3 to 1 does the trick.
I'm trying to derive the Ruby commands to do this programmatically.
Greg
Greg
Hi Greg,
Please look again at the suggestions. Neither Tom nor I said to turn off Display edges. We said to turn off Profiles, and gave 2 ways to do it.
As for the Ruby commands...
Sketchup.active_model.rendering_options["DrawSilhouettes"]=false
Register LoginAdvertisement
