    How do you Make Thin Lines?
    5 Posts 3 Posters 7.3k Views 3 Watching
      Greg
      Hello,
      I thought this would be easy, but I don't see how to make the lines in the objects thin. They are thin when I move the object, but as soon as the object stops the lines change to thick, like going from pen to magic marker.
      Is there a way to make and keep the lines thin?
      Thank you.
      Greg
        Jim
        Greg,
        View: Edge style: Profiles unchecked?
          tomsdesk
          I'm gonna guess you have "profile edges" selected: go into the "display settings" menu in SU5 (the "styles" menu, "edges" tab, in SU6) to check...?
          2.5D Trees & Shrubs!
            Greg
            Thanks Jim and tomsdesk. Unchecking 'Display Edges' does not do it because I'm using lines to simulate empty bins in a virtual warehouse, but setting the line profile from 3 to 1 does the trick.
            I'm trying to derive the Ruby commands to do this programmatically.
            Greg
              Jim
              Greg
              Hi Greg,
              Please look again at the suggestions. Neither Tom nor I said to turn off Display edges. We said to turn off Profiles, and gave 2 ways to do it.
              As for the Ruby commands...
              Sketchup.active_model.rendering_options["DrawSilhouettes"]=false
