    Modeling a net
    5 Posts 3 Posters 694 Views 3 Watching
    • P
      perk
      I am in need of modeling some batting cages and I dont even know where to begin modeling the net or cage surrounding it. Anyone have any suggestions?
      Thaks
      Jeff
      • R
        remus
        Use a .png image to texture it. .png files support transparency, so youll be able to get a texture that you can see through.
        If you dont fancy making your own, i think theres a chainlink texture in the materials browser. If you apply this to a surface representing the net and then play about with the colors a bit you should be able to get something lookign pretty good.
        I fyou need to get a shadow, you might want to try following the instructions given here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=22&t=6687
        • S
          sketchy
          check this thread out as well
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=79&t=3339&p=16478&hilit=cage#p16478
          • P
            perk
            I'll give it a try. Thanks Remus
            • P
              perk
              Sketchy
              That is exactly what I was looking for
