    Multiple file extensions in openpanel
    24 Posts 6 Posters 2.6k Views 6 Watching
      Jim
      I know that the following will display only folders and zip files in the openpanel dialog:
      fn = UI.openpanel "Select a zip file.", "",  "*.zip"
      Is there a way to specify more than one file extension, like .zip and .rb?
        Jim
        Answer to my own question: use a semi-colon:
        fn = UI.openpanel "Select a zip file.", "",  "*.zip;*.rb"
          todd burch
          Thanks Jim. I have updated the Ruby Wiki Doc. http://groups.google.com/group/SketchUp-Plugins-Dev/web/Ruby-UI.html?hl=en
          Todd
            Jim
            I think that's a Windows thing, not strictly a Ruby thing.
              todd burch
              You are correct. I updated it to qualify that tip for Windows users. Thanks.
              • Al HartA Offline
                Al Hart
                When I tried this in SU 7 on XP and Vista, the openfile panel displayed only the .zip files, (no .rb files), and showed this '*.zip;_.rb' in the File name box: (with an underscore instead of a *)
                When I pass it just one extension, it works:
                But if I pass it a starting folder it fails:
                UI.openpanel "Select a zip file.", "c;/tmp",  "*.zip"
                showing '_.zip' in the File Name box
                Any thoughts. (Or maybe its just my machines)
                Al Hart
                http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
                IRender nXt from Render Plus
                  todd burch
                  Smells like a bug. Report it.
                  • Al HartA Offline
                    Al Hart
                    Thanks Todd.
                    I did in this other thread
                    Is there a better place to report Ruby bugs?
                    Actually, I was hoping I was doing something wrong, or that there was a workaround. šŸ˜ž
                    Al Hart
                      Jim
                      I just checked in V6 Pro and it works as expected. V7 Pro appears to be borked.
                        todd burch
                        Thanks for testing Jim.
                        Al, that's as good a place as any.
                        A guy over on the Ruby API on Google Groups found an interesting bug the other day. I reported it. http://groups.google.com/group/sketchupruby/browse_thread/thread/cea693f78613f521/d1baffa49e08010a#d1baffa49e08010a
                        In summary, a 4 sided face was getting created with only 3 vertices.
                          todd burch
                          That's news to me!! I've made several, although no exhaustive, changes there.
                          Who said that - Google? It would be nice if two things were to happen if that's the case:
                          1. Tell the people who do use it
                          2. Get rid of it (without losing the updates that were made)
                          When the Ruby Wiki was first put together, I asked the question "Will these changes get integrated into "official" the Ruby Help system" The answer I got back was an overwhelming "we don't know, but there it is - update it as much as you want."
                          Then, the next thing I see up at code.google.com was this web site: http://code.google.com/apis/sketchup/docs/developers_guide/index.html
                          There was no external-to-Google announcement (like an email to concerned citizens) or promotion of this web site (other than a no-fanfare link or two) that I am aware of, so then we had (and now we have) 3, count 'em, 3 different sources for doc.
                          For some time now, I have slacked off of updating the Ruby Doc Wiki, as it appears to me, unless I can be told different, that my updates are falling on deaf ears.
                          It's a mess. Someone at Google needs to decide of they want the doc updated, for free, by volunteers like us, and if so, there needs to be a process put in place that our changes make it to whatever is deemed to be the official doc in a timely manner. I mean, it's HTML for Pete's sake - not even a PDF. Maybe we need a "docforge" system???
                          Todd - not happy about this at all.
                          • Al HartA Offline
                            Al Hart
                            That's why I added the comment about the Wiki no longer being active - because a Wiki where we could help with the documentation would be a good idea.
                            Also, now that Peter, Scott and others at SketchUp were starting to develop things using Web Dialogs and Ruby, I was hoping they would help to improve the language it self and the documentation.
                            I'll pass this thread along to the person at Google who replied to the request to join the Wiki group, and maybe we can all come up with something which Google and some outside developers (by request and/or invitation) can help with.
                            I liked the idea that you were updating the documentation.
                            Al Hart
                            • Chris FullmerC Offline
                              Being totally new here, I echo Todd's frustration with having 3 sources for the API. I have a hard time telling which of the 3 I'm actually in. All I know is that things are documented slightly differently in different palces and sometimes the wiki has the best syntax and usage info (which is what I normally need TONS of help with).
                              Poor/multiple/unregulated/disorganized documentation has been a large frustration of mine with SU, and now that I'm looking at Ruby, its only gotten worse. I wish they would put more effort into making the info more complete and the process more transparent. I really would like to code in Ruby and I have some great ideas, and I'm getting there. But its very frustrating feeling like my #1 hinderance to learning is the SketchUp API.
                              Chris
                              All my Plugins I've written
                              • Al HartA Offline
                                Al Hart
                                Todd
                                Is this Wiki being kept up to date.
                                I tried to join it and got this response:
                                %(#BFFFFF)[This is a group that never really went anywhere, so we aren't actually using it.
                                Thanks for checking, however!]
                                **Added later:**After the initial posting of this post, Mark apologized that he was thinking of a different group:
                                BTW, I see that I was quoted in the forum. If you wouldn't mind updating that to include
                                that I was wrong, that this wasn't the group I thought it was, I'd appreciate it. I don't
                                want folks to be misled because I got confused.
                                Al Hart
                                • Al HartA Offline
                                  Al Hart
                                  Since my original posting of Mark's reply about the Wiki group, Mark has apologized. He was thinking of a different group:
                                  Al Hart
                                  • Al HartA Offline
                                    Al Hart
                                    I looked at this ruby documentation source and was surprised to see that Sketchup.load was not even on it. 😢
                                    Al Hart
                                      todd burch
                                      Yes, it's a 3-way mess.
                                      • Tyler MillerT Offline
                                        Tyler Miller
                                        Hey guys -
                                        We hear you loud and clear about the documentation mess. We're working hard to resolve it.
                                        -Tyler
                                          todd burch
                                          Thanks Tyler.
                                            @tyler miller said:
                                            Hey guys -
                                            -Tyler
                                            Ooooh! So good to hear this! šŸ‘ šŸ‘
                                            • 1 / 2
