    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.0m Views 150 Watching
      dondanev
      hvala puno ako ko razume thanx
        rv1974
        Hi Fredo!
        I thought about some enhacement of the single face JPP. It should respect the adjacent faces (AB and CD keep their directions while BC is moving forward (example 2)). It works in revit and I think it would be great especially in architectiral practice.
        P.S. Basicly instead of single BC face there could be any number of faces- it's all about vicinity treatment.
        Thanks in advance
          JaViXP
          I have translated this plugin into Spanish, how can I change the default language?
          "Giving up is way harder than trying"
          JaViXP's Rendering
          • fredo6F Offline
            fredo6
            Normally you'll get the spanish version if your Windows or Mac system is in spanish.
            To force the language, just create a file LibTraductor.def(or edit it if it already exists), and make sure the one line code is:
            TRADUCTOR_DEFAULT = "ES"
            Fredo
              JaViXP
              It displays an error for me, could you please do it? (JPP text is below)
              Thanks 😄
              JPP Text.txt
              JaViXP's Rendering
                magpie
                many thanks again fredo!
                • P Offline
                  Patrickpr
                  Hy
                  What is this?
                  LibTraductor.def, an optional configuration file allowing override of language
                  i Have the german version
                  I can that not install 😢 😢 😢
                  • fredo6F Offline
                    fredo6
                    @patrickpr said:
                    Hy
                    What is this?
                    Patrick,
                    Unfortunately, JointPushPull is an old script and the translation must be done in the code of the script itself (line 29 to 168 of jointpushpull.rb).
                    The convention is to add the strings in the existing lists as "|DE| the text", being careful to put a \ before any accentuated or special character (and also careful with the Ruby syntax). Usually, I do it myself, based on translation provided by contributors in text files.
                    Fredo
                    PS: I plan a refresh of JPP one of these days, based on LibFredo6. Then the translation can be done in an easier way, like in FredoScale or HoverSelect, and in much more languages.
                      JaViXP
                      That sounds cool 👍
                      I'll try to translate it into Spanish 😄
                      JaViXP's Rendering
                      • simon le bonS Offline
                        simon le bon
                        Bonjour Fredo,
                        "Please help!"
                        I don't know why, JointPushPull doesn't close the borders anymore!!"Snarrgg" - - Even if I indicate in configuration menu "borders on external faces" (traduction~!). But it continues to close the sides when I indicate "Borders on all the faces"...
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_001.jpg
                        I don't think so because I had already made some tries but may be the version of LibTraductor.rb plays in this fail?
                        The one given in the zip package is 13 732 bytes 20/01/2008
                        and I use the recent one given with BezierSpline v121 : 19 331 bytes 07/07/2008
                        Or may be it is a cause from one of the plugins I have recently installed ❓
                        Please Fredo, what can you advise me. (I don't know nothing with ruby console, code etc..)
                        --simon.
                        • fredo6F Offline
                          fredo6
                          Simon,
                          I don't think this is related to LibTraductor.
                          Normally, when you start up Sketchup, the default option is always to create the border faces.
                          Is this what you observe ?
                          Fredo
                            simon le bon
                            Dear Fredo,
                            Thanks for replying.
                            JointPushPull is now a basic tool for me. To see it not working makes me nervous 💚
                            Here is a more complete report:
                            ( it is more easy to me to explain in pictures )
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_002.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_003.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_004.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_005.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_006.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_007.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JointPushPull550_008.jpg
                            What more test can I do?
                            --simon
                            • fredo6F Offline
                              fredo6
                              Simon,
                              Thanks.
                              Although this seems strange, I'll check where the conflict could be.
                              By the way, did you install LibFredo6 3.2a yet, or are you still running an earlier version?
                              Fredo
                              • fredo6F Offline
                                fredo6
                                Simon,
                                This has nothing to do with HoverSelect, but with LibFredo. The bug is more subtle than that: it is actually related to how SU and dialog boxes handle accentued characters in drop down controls.
                                It only exists in the French version of JPP, because of the text "Bordures sur les faces extérieures", which contains an accent.
                                As a result, any call to the dialog box via TAB would make the Border option void.
                                In any case, you can change all options using Function keys (F5 to toggle for Thickening, keep face, erase face) for instance, or via the Contextual menu. This works regardless of the above bug.
                                Attached is a quick fix to JPP (just removed the accent), but the real fix is in LibFredo. I simply need more time to make it and validate, as this is now shared in all my plugins.
                                Fredo
                                PS: Thanks to advise is OK
                                jointpushpull.rb
                                  simon le bon
                                  Héy Héy Héy !!!!
                                  Merci so much Fredo,
                                  Tout est Ok maintenant 😆
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/JppIsBack.jpg
                                  And some shame on me -1) Not to have thought to download LibFredo6 3.2a last version. 😳 I was v3.1
                                  -2)I also hadn't thougth to remove from SU\Plugins the previous LibFredo Directories !!
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/libfredo.jpg
                                  But at last it was not an unnecessary call to you because of this problem with accentuation..
                                  PS: I had completely missed using Function keys and now I'm going to look at them better.
                                  So much thanks for everything you do,
                                  Simon.
                                    simon le bon
                                    Cher Fredo,
                                    I have finally found from where have coming the problem. In a sense it is reassuring because it's coming from you!!
                                    I have searched over the last plugins I had installed, removing them one by one, to discover from where was coming the clash.
                                    It's coming from two of them, and they are yours: ZLoader__FredoScale.rb and ZLoader__HoverSelect.rb
                                    (And this can help: no problem with: ZLoader__OnSurface.rb >> JointPushPull works well)
                                    I'm happy because i'm now sure you will find the hit...
                                    😄 simon.
                                      mpowell1234567890
                                      Cool, I noticed the the jointpushpull.rb attachement on this forum dated August 2nd. It is the updated version vurses the older version on the 1st page of this forum?
                                      Simon,
                                      Fredo
                                      • fredo6F Offline
                                        fredo6
                                        It just fixes the problem signaled by Simon, which only deals with the French translation. There is no other change. So I am not sure you need to download it.
                                        I'll publish soon an update to LibFredo6 to fix this bug.
                                        Fredo
                                          mpowell1234567890
                                          Fredo
                                          Cool, thanks. Just checking because last time I tried to use jointpshull.rb a while back, it kept creating bugsplats everytime I selected a surface to pull.
                                          • fredo6F Offline
                                            fredo6
                                            Small updatepublished in the main thread, mainly:
                                            • to put the menus into a submenu of the Tool menu
                                            • to resolve the problem of Toolbar persistence on Mac
                                              I did make these modifications earlier in April but forgot to update the main post.
                                              see http://forums.sketchucation.com/viewtopic.php?f=180&t=6708&p=42783#p42783
                                            Fred
                                            • 6
                                            • 7
                                            • 8
                                            • 18
                                            • 19
                                            • 6 / 19
