    Windy Mountain Roads
    11 Posts 8 Posters 3.3k Views 8 Watching
    • T
      TheFlux
      Hello folks,
      I'm trying to work out the easiest and most effective way of modelling windy mountain roads. The stamp tool doesn't really have the desired effect and the drape tool also isn't really doing it for me. Ideally, if I had a Bezier curve that I could use in 3d space and not locked in 2d space then I could just use the follow me tool. However saying that, the road still might end up being slanted and not flat. If you can decode what I'm trying to say and have a solution I would be very grateful 👍
      • Alan FraserA
        Alan Fraser
        If you are doing it commercially and on a regular basis, then SimuTerra would be a good choice.
        3D Figures
        • T
          TheFlux
          Thanks Alan, I'll check it out.
          • R
            remus
            is this the sort of thing you were thinking of? If it is i'll do you a quick tut.
            • A
              a4chitect
              remus if you found a quick way to create a road on a curved surface without the disadvantages of simple draping (road is not always horizontal in its cross section) please show us how!!! (I can only achieve acceptable results with lot of hard manual work and there is lot of complicated geometry involved)
              thanks
              • R
                remus
                No secret really, and not a particularly good method. I just did it by turning on hidden geometry, selecting a reasonably continuous line for the road and moving it down a bit to get a reasonably flat surface, i then just ment over it with the move tool locking it vertical all the time. sorry to dissappoint 🎉
                • charly2008C
                  charly2008
                  Hello scf Members,
                  it seems to me that many Sketchup users would like to create realistic looking roads on a curved Terrain in Sketchup. This is also one of my interests. I started a discussion about here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=19276
                  I tried to construct a road with the "FollowMe and keep" plugin. First i draped a single line on the terrain and than i extruded a face along this line with the above mentioned plugin. The road is horizontal in its cross section. But the whole process is not yet satisfactory.
                  Karlheinz
                  Riedberg14.skp
                  Alpen15.skp
                  • B
                    bocomofo
                    Attached is a rather nasty little tutorial hastily thrown togehter. Although the results are not perfect it may be an alternative method of trying to achieve the desired result. Think this will only work on relatively straight roads...
                    hopefully of some use!
                    joe
                    Alpen15 - with path.skp
                    • charly2008C
                      charly2008
                      Hi Joe,
                      thanks for your efforts. This methode is similar to the FollowMe and keep plugin. It is always the problem that the road follows strictly the drawn line. May be we will find a solution.
                      Karlheinz
                      • G
                        garymo
                        Have you tried the 1001 bit tools, if not have a look at the help/tutorial files.
                        • P
                          Physicsguy1
                          I suggest drawing the road outline, push/pulling it, placing it in the desired position on the terrain, and intersecting. delete the faces and you have a road.
