    Edges opacity adjusting problem
    6 Posts 4 Posters 1.6k Views 4 Watching
      alr
      I can get the visual results of the material/color opacity adjusting, when the material/color assigned to a FACE. But when the material/color assigned to an EDGE I can't get any visual effect, after adjusting of the material/color opacity.
      Why?
      • boofredlayB Offline
        boofredlay
        Opacity for edges is not supported in SU.
          alr
          Thank you very much for saving of my time from useless experiments!
          • AnssiA Offline
            Anssi
            The effect is very easy to achieve in Photoshop. Export a colour image with shadows etc. but with edges turned off. Export a second image, as a hidden-line line drawing without shadows. Put the line drawing as a layer above the colour image, set the layer mode to Multiply or Darken, and adjust the layer transparency slider until you get what you want.
            Anssi
              alr
              @anssi said:
              Thank you, Anssi, - it's a very useful technique for standalone pictures!
              It’s a pity, but according to my task I would like to have the opacity adjusting inside SketchUp session.
              I have got that in current version of SketchUp it’s impossible.
              Good luck!
              • P Offline
                Phil Rader AIA
                you can change the color of the lines from black to grey but they will still not be transparent.
                http://www.philrader.com
