    WIP Animation
    14 Posts 7 Posters 1.3k Views 7 Watching
    • tinanneT
      tinanne
      I would like any help that can be offered. I'm doing some test runs with some of the information I've already gathered from Paul's thread and suggestions from Kris. I will post the progress later.
      You can view what if done so far here... http://www.illustrationz.com/sumodels.html
      I started a different thread with my problem child so not to hijake Paul's wonderful work. I wouldn't want mine to be confused with his. Actually, I would, but I'm sure HE wouldn't!! He does beautiful work, check it out! viewtopic..
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=125&t=5968
      Executive Director : American Society of Architectural Illustrators
      AIP 30 Competition opens soon. ASAI.org
      Architectural Rendering
      • tinanneT
        tinanne
        Ok, this is what I have so far. Deadline is tomorrow!!! Paul are you out there!!!! πŸ˜„
        It got really jumpy when I extended the length of the frames to slow down the rotation, but I think I've figure that problem out. I'll upload an update later this eve.
        Thanks, for any help.
        • soloS
          solo
          Tinanne
          If I may (I am not sure as to the entire story of what you are wanting to achieve), I normally set my scene transitions to 0 (zero) and my scene delay to 3 (three) that normally produces smooth animations.
          http://www.solos-art.com
          • tinanneT
            tinanne
            Thanks Solo. I've actually been putting the movie together in Premiere Elements. I've been going off of a tutorial that Paul Russam has created, but I'm open to any suggestions. πŸ˜„
            • spenceS
              spence
              I think what you have looks great. I never attempt animation in Sketchup anymore after playing around with Vue6, it has ruined me. So now that I see what you have done, I like it, you have done a great job. This is what has ruined me http://www.e-onsoftware.com/products/vu ... layout.php
              Spence
              • Paul RussamP
                Paul Russam
                Hi, sorry I didn't reply sooner but I've been away this weekend.
                Changing the speed of a clip:
                In Premiere Elements right clip on the clip and select 'Time Stretch...' you will be presented with a dialog. change the speed by typing a persentage value.
                Remember if the clip is trapped between 2 other clips it will not be able to 'expand' its length so will get truncated to the available length. To get around this, drag the clip to a clear area of video track, change its speed and then rearrange the other clips to make room for it.
                Notes:
                On the same 'Time Stretch...' dialog there is an tick box called 'Reverse speed' this will play the clip backwards.
                You can put in '-' values for the speed eg -25% will play the clip backwards at 1/4 the original speed.
                Hope this helps.
                Paul Russam
                English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                • tinanneT
                  tinanne
                  Paul, thanks for responding πŸ˜„ I did figure out how to do the "time stretch" but what seems to be happening as a result is that the scenes I stretches are jumpy? I did another test exporting as a .m2v and it seems to be much smoother? Any thought on that?
                  Spence, Vue looks very cool! I've heard about it "around town". I'll look into it more soon. Thank you.
                  Mateo, great presentation! Thank you for showing it to me. I wish I had more time! Due today, under pressure. I will most likely revisit this one when I've gotten more "seasoned". Thank you for your compliments. My site is in need of a refresh, badly. I think it's been 9mo since I've put anything new up. Shame on me!
                  • A
                    andyc
                    Re: the jumpiness. Have you checked the frame rate of your export in SU and in Premier (under 'options' in the animation export window in SU)
                    29.97 is the standard for smooth animations, but you can get away with less. Also if the frame-rate of the export from premier is different (ie 24fps) you'll get some jumping as frames are missed.
                    hth
                    A.
                    • tinanneT
                      tinanne
                      hth
                      A.
                      I exported at 25fps in both cases... I thought I may have figured it out, but not sure. I added "keyframes", it seems to have smoothed it out a bit but maybe I should add more or maybe there is another way?
                      • tinanneT
                        tinanne
                        Well, the deadline arrived and I just had to stop working on it. I can already see things I'd do differently. Still a bit jumpy 😞 Couldn't figure it out.
                        Thanks for all your help
                        • tinanneT
                          tinanne
                          I can't seem to get a good connection to that animation. When it's played it's so choppy, it's terrible. It really did come out kind of nice, so I'll keep trying to figure it out and upload it again. Maybe I should try youtube or the file server here?
                          • tinanneT
                            tinanne
                            OK, I think it's finally up with decent quality. It still hangs up a little in spots, I think while it's buffering. When it's starts to hang up I just started it over and it played nicely.
                            I've already gotten some great info, but I wanted you to see the final that will be given to the client. I want to start offering more of these, so any information is great and helpful. Thanks to all!
                            • boofredlayB
                              boofredlay
                              That one played much better.
                              Great work, thanks for sharing.
                              • M
                                mateo soletic
                                Tinnane,
                                I saw Your thread Yesterday. The reason I didnt reply
                                then it is because I couldn t explain it so much in words
                                but in a form of a similar presentations that I make.
                                Although Your presentation is a great start I have a
                                couple of suggestions and tips.
                                Most of your Animation is apart from one or two
                                sequences is actually a slide show. Slides,
                                graphics, transitions, and proper design presentations
                                can be dynamic and interesting even without or with
                                very small amounts of animated sequences.
                                By the way I have visited Your web site on several
                                occasions and I really like Your work and I think
                                it would benefit even more if You take this approach .
                                Here is a link to my thread.
                                viewtopic.php?f=10&t=3022&hilit=
                                Concept Illustrations
