    Sketchup + artlantis
    20 Posts 11 Posters 1.8k Views 11 Watching
      mike d
      just learning artlantis here is one of the first rendering that i am happy with comment welcome
      thanks
      mike d
      The grass is always GREENER on the roof.
      • EdsonE Offline
        Edson
        mike,
        so far all i can commment is that i envy the fact you started with it. i have artlantis, bought a good guide about it but so far i have not had the time to learn it. let us know how you do.
        cheers.
        http://www.mahfuz.arq.br
          mike d
          edson
          so far it's not been to bad to learn
          alot of trial and error the hardest
          thing so far for me has been figuring out
          how the material system worked but once
          you get the hang of it. it's not to bad
          been working with it about a week now
          mike d
          • soloS Offline
            solo
            Mike,
            How is the speed?
            And is the UI easy to navigate?
            http://www.solos-art.com
            • boofredlayB Offline
              boofredlay
              That looks great Mike. Makes me want to buy a tie and a pair of slacks.
                mike d
                solo
                the its not to bad took about 15 min to render at 4800x2400
                the company that i work for is making me learn it
                eric
                thanks
                mike d
                  mateo soletic
                  Great start Mike. Join the club. I havent really tried artlantis but it is worth a while to spend some time on the render forum or the app You are using.Another tip those SU
                  cars will get better with practice but will never get too realistic in close ups. They can bring down the whole image. The alternative is to use cut-outs or buy high polly bundle models in other formats and render them separatelly or together.
                  Concept Illustrations
                  • H Offline
                    holgster
                    Looking good Mike.
                    You can find lot's of good objects that you can insert in Artlantis at http://www.archiradar.it/
                    The site is Italian but the download section is easy to find.
                    Try using the fresnel glazing material for your glass, you'll be amazed.
                    I really love Artlantis for it's straightforward material assignment and incredible speed of rendering.
                      Loewenkatze
                      Hi Mike,
                      what AA-settings did you use? Looking at the cars I feel Artlantis can do this better than it looks here.
                      The windows look a little bit artificial to me. Maybe darkening the surface a bit might help ... in a kind of blue-gray if you like them to reflect the sky. Or playing with the other parameters for glass-shaders...
                      Beside that you did a good start with your first Artlantis render, to my mind.
                      Cheers,
                      Franziska
                      "I think play is the most important thing in the world." [Jacques-Yves Cousteau]
                      • AnssiA Offline
                        Anssi
                        Mike,
                        It's a good start. I like ArtLantis a lot too for its speed and relative ease, but once you get the hang of its materials and lighting, I find getting rid of the characteristic a bit plasticky "Artlantis look" is somewhat challenging. Maybe it is mostly about texturing, the standard materials are not particularly good.
                        Anssi
                          mike d
                          thanks guys
                          mike d
                            mike d
                            here is an updated image
                              cheffey
                              Looking good Mike.
                              I like Artlantis, I think it's pretty easy to use. I think you could add a bit of reflection to the cars and maybe put something in front of your model so that it will reflect in the windows.
                              Some people use the same model, make a component and rotate 180. Look forward to seeing your progress.
                              BROS RŌMAN BRÄUN
                                mike d
                                here is a new updated image
                                i think its getting better what do you think
                                mike d
                                  boofredlay
                                  I am diggin' those reflections. 👍
                                    bubbalove
                                    The reflection on the road is a little strong. It looks like it just got done raining.
                                    "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                      mike d
                                      david
                                      that is the effect that i was going for
                                      mike d
                                      • jenujacobJ Offline
                                        jenujacob
                                        neat!! run it thru Squirlz to get some drizzle and voila! 😉
                                          boofredlay
                                          I was thinking the same thing about the rain. Maybe put some clouds in the background, like the storm front just passed.
                                          Great work.
                                            mike d
                                            here is a revised image with the scene a little bit brighter and the rain gone from the parking lot
                                            thanks
                                            mike d
