    Text position problem
    23 Posts 5 Posters 3.9k Views 5 Watching
    • J
      Jorgensen
      I'm working on my very own (noooooob) area script.
      And now I'm having my first problem - when add a text to a face in Sketchup, by doubbleclick, the text is visible from allmost every angle, but if I use
      coordinates = object.bounds.center
      model = Sketchup.active_model
      entities = model.entities
      point = Geom::Point3d.new coordinates
      $area = (object.area / (39.3700787*39.3700787)).round
      $text = "#{object.layer.name}\n#$area m2"
      $textObjects.push(entities.add_text $text, point)
      It seems like the text is being cut by the face - is there a way to avoid this ?
      And a other small thing - how do I add a ² to the areatext ?
      Jorgensen
      Here is the complete script:
      $textObjects = Array.new
      def tmTextAdd
      tmSelectAllFaces
      ss = model.selection
      for object in ss
      ss.clear
      def tmSelectAllFaces
      ss.clear
      for ent in model.entities
      if (ent.kind_of?(Sketchup::Face))
      ss.add(ent)
      def tmTextDelete
      if $textObjects.length > 0
      $textObjects.each do |e|
      if(not e.deleted?)
      e.erase!
      $textObjects.clear
      #tmSelectAllFaces
      #tmTextAdd
      #tmTextDelete
      #- Setup menu -
      if(not $TM_area_loaded)
      Mejeriet_menu = UI.menu("Plugins").add_submenu("TM").add_submenu("Arealer")
      Mejeriet_menu.add_item("On") { tmTextAdd }
      Mejeriet_menu.add_item("Off") { tmTextDelete }
      $TM_area_loaded = true
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • A
        azuby
        I've done a bit cosmetics to your script and put all the code togehter (you wrote, "complete script", but the text-adding wasn't in)
        def tmTextAdd
          tmSelectAllFaces
          for object in ss
            point = Geom;;Point3d.new object.bounds.center
            text  = "#{object.layer.name}\n#{area} m²"
            $textObjects.push entities.add_text(text, point)
          ss.clear
          ss.clear
          for ent in model.entities do
              ss.add ent if ent.kind_of? Sketchup;;Face
        def tmTextDelete
          unless $textObjects.empty?
            for e in $textObjects do
              e.erase! unless e.deleted?
            $textObjects.clear
        #- Setup menu -
        unless $TM_area_loaded
        And for me it worked. I can see all texts from all directions.
        azuby
        • J
          Jorgensen
          Hi azuby
          Thanks for your help - but I still have the problem that the text gets cut off - se images.
          The 'test' text is added via mouseclick and does not have this problem 😞
          EDIT
          Is this the proper group/place for such technical questions ?
          • A
            azuby
            Hmmm maybe it's a problem with OpenGL?
            azuby
            • J
              Jorgensen
              If I afterwards manual move the text 200mm, on the blue axis, the problem dissapers.
              But how do I do this automatic ?
              point = Geom::Point3d.new object.bounds.center
              Adding 200mm to the Z axe of point ?
              Sorry, I have quite a lot questions.... and still a lot to come
              Jorgensen
              • Didier BurD
                Didier Bur
                Adding a small leader to the text would solve the problem (if you don't mind having such text)
                For instance:
                text = model.active_entities.add_text "your_text_here", point, Geom::Vector3d.new(0,0,10)
                increase vector.z value to get greater leader. What I often do is to have the same value for text height and vector.z value
                Hope this helps,
                DB
                • J
                  Jorgensen
                  Thanks Didier - I added point.z = point.z + 6 - this helped 😄
                  Jorgensen
                  • Didier BurD
                    Didier Bur
                    BTW, your way of calculating (converting from inches2 to m2) areas is quite strange.
                    Try this:
                    $text=Sketchup.format_area object.area
                    Whatever unit the user has set, area (numeric) will be converted to this unit (string) and a ² is added to the text as well 😍
                    DB
                    • J
                      Jorgensen
                      Hi All
                      Thanks for your input.
                      @Didier
                      I have tried that - belive me - but I don't no why, but if I do an Object.area on a face that is 1000x1000mm I get an area of 1,550m2 ? And I have setup units in Model Info - strange ???
                      Another problem. If I doubbleclick the mouse I get a 'attaced' text, that keeps the position inside the face, even if I move the sides. This does not happen when using Object.add_text 😞 does any know if it is possible to achieve this by script ?
                      What I'm trying to create is a small script that has the function as I have tried to sketch on the attached image. This would be very useful for me when sketching plans 😄
                      The next problem - how do I get group names, add listing them inside a group and adding text inside this group - a lot to learn..... 😞
                      • Didier BurD
                        Didier Bur
                        Jorgensen,
                        Try attached script.
                        Acces it via context menu, when a single face is selected in the model.
                        It creates a formatted text on a layer "Areas".
                        For the rest, I don't understand exactly what you mean (groups, and so)...
                        txt_area.rb
                        DB
                        • J
                          Jorgensen
                          Hi Didier
                          I will have a look at the script.
                          What I main by groups. Is, that I have:
                          • a ground level wich is on Layer 00
                          • first floor in layer 01
                          On layer 00 (ground level), I would like a group that contains a 'area group' for each room, Kitchen, livingroom, and so on... .Each areagrop should have the name of the room, so that a script, can update the Text and area.
                          So, in the maingroup on layer 00, holds a text (on layer 0t Text) that says kitchen size ...., and a group named Kitchen (on layer 0A Area, so it can be turned off).
                          A bit dificult to explain 😞
                          Jorgensen
                          • Didier BurD
                            Didier Bur
                            OK, I understand.
                            This is doable, but I have not much time to help you by now 😢
                            Remind me...
                            DB
                            • J
                              Jorgensen
                              Hi Didier
                              Thank - you have allready helped. I'll se what I can fix myself.
                              By the help from this forum, it might be possible 😄
                              Jorgensen
                              • J
                                Jorgensen
                                I have a question about the Sketchup.format_area utility.
                                My model is in mm, but I would like the result to be in m2 not as Sketchup.format_area shows mm2 - is this somehow possible ?
                                • J
                                  Jorgensen
                                  Its now going the right way... 😄
                                  I have one question.
                                  I have a group on each level of the building (the levelGroup). Each levelGroup contains a number of groups, that holds info for each room, the area and name. roomGroups.
                                  I then doubbleclick, and get inside a levelgroup, and update the roomGroups.
                                  To keep track of the roomGroups I use:
                                  target = Sketchup.active_model.active_entities;
                                  $areaObjects.push target.add_text text, coordinates
                                  I then have an array $areaObjects, that cointain all the text added (roomGroups).
                                  If I wan't to delete/update all the text, I can read the array again and then erase! them, but this will delete all the text on in all levelGroups.
                                  Is there a way to tjek if the roomGroup is inside the active group ?
                                  Jorgensen
                                  • Didier BurD
                                    Didier Bur
                                    Yes:
                                    Switch to meters unit just before the format_area instruction, then switch back to mm:
                                    old_unit=Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                                    Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]=4
                                    then_call_the_format_area_instruction_here
                                    (result is a string so it would'nt be affect by later changes)
                                    Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]=old_unit
                                    (to switch back to mm in your case
                                    DB
                                    • J
                                      Jorgensen
                                      Hi Didier
                                      Thanks for your reply. Just the way I would do, I just could'nt find the settings in Ruby.
                                      One problem however, the text now becomes 14 Meters2 - should be 14 M2 - I guess I'll have to do somekind ereg_replace....
                                      Thanks for your help.
                                      Jorgensen
                                      • J
                                        Jorgensen
                                        Easy area = area.sub("eters ", "") 😄
                                        This is fun 😍
                                        • TIGT
                                          I did an AreaFormat tool a while ago... see: http://www.sketchucation.com/forums/scf/viewtopic.php?p=12808#p12808
                                          It could easily be adjusted to suit your current units if they are not listed...
                                          • J
                                            Jorgensen
                                            Thanks TIG - I'll have a look at it...
                                            Right now I have a problem, actual the last before I can use the script at work...
                                            I use this to tjek and delete objects in the active group:
                                            def tmAreaDelete
                                            objects_active = Sketchup.active_model.active_entities
                                            for object in objects_active
                                            if($areaObjects.include?object)
                                            object.erase! unless object.deleted?
                                            $areaObjects.delete object
                                            What teases me, is I have to run the tmAreaDelete tree times to delete all text objects - and I just can't se why 😞 It works if I skip the line '$areaObjects.delete object' but that can't be a good solution.
                                            Jorgensen
                                            • 1 / 2
