๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Text position problem
23 Posts 5 Posters 2.5k Views 5 Watching
    Jorgensen
    I'm working on my very own (noooooob) area script.
    And now I'm having my first problem - when add a text to a face in Sketchup, by doubbleclick, the text is visible from allmost every angle, but if I use
    coordinates = object.bounds.center
    model = Sketchup.active_model
    entities = model.entities
    point = Geom::Point3d.new coordinates
    $area = (object.area / (39.3700787*39.3700787)).round
    $text = "#{object.layer.name}\n#$area m2"
    $textObjects.push(entities.add_text $text, point)
    It seems like the text is being cut by the face - is there a way to avoid this ?
    And a other small thing - how do I add a ยฒ to the areatext ?
    Jorgensen
    Here is the complete script:
    $textObjects = Array.new
    def tmTextAdd
    tmSelectAllFaces
    ss = model.selection
    for object in ss
    ss.clear
    def tmSelectAllFaces
    ss.clear
    for ent in model.entities
    if (ent.kind_of?(Sketchup::Face))
    ss.add(ent)
    def tmTextDelete
    if $textObjects.length > 0
    $textObjects.each do |e|
    if(not e.deleted?)
    e.erase!
    $textObjects.clear
    #tmSelectAllFaces
    #tmTextAdd
    #tmTextDelete
    #- Setup menu -
    if(not $TM_area_loaded)
    Mejeriet_menu = UI.menu("Plugins").add_submenu("TM").add_submenu("Arealer")
    Mejeriet_menu.add_item("On") { tmTextAdd }
    Mejeriet_menu.add_item("Off") { tmTextDelete }
    $TM_area_loaded = true
      azuby
      I've done a bit cosmetics to your script and put all the code togehter (you wrote, "complete script", but the text-adding wasn't in)
      def tmTextAdd
        tmSelectAllFaces
        for object in ss
          point = Geom;;Point3d.new object.bounds.center
          text  = "#{object.layer.name}\n#{area} mยฒ"
          $textObjects.push entities.add_text(text, point)
        ss.clear
        ss.clear
        for ent in model.entities do
            ss.add ent if ent.kind_of? Sketchup;;Face
      def tmTextDelete
        unless $textObjects.empty?
          for e in $textObjects do
            e.erase! unless e.deleted?
          $textObjects.clear
      #- Setup menu -
      unless $TM_area_loaded
      And for me it worked. I can see all texts from all directions.
      azuby
      *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SUยฒCATT
      Bad English? PM me, correct me. :smile:**
        Jorgensen
        Hi azuby
        Thanks for your help - but I still have the problem that the text gets cut off - se images.
        The 'test' text is added via mouseclick and does not have this problem ๐Ÿ˜ž
        EDIT
        Is this the proper group/place for such technical questions ?
          azuby
          Hmmm maybe it's a problem with OpenGL?
          azuby
            Jorgensen
            If I afterwards manual move the text 200mm, on the blue axis, the problem dissapers.
            But how do I do this automatic ?
            point = Geom::Point3d.new object.bounds.center
            Adding 200mm to the Z axe of point ?
            Sorry, I have quite a lot questions.... and still a lot to come
            Jorgensen
              Didier Bur
              Adding a small leader to the text would solve the problem (if you don't mind having such text)
              For instance:
              text = model.active_entities.add_text "your_text_here", point, Geom::Vector3d.new(0,0,10)
              increase vector.z value to get greater leader. What I often do is to have the same value for text height and vector.z value
              Hope this helps,
              DB
                Jorgensen
                Thanks Didier - I added point.z = point.z + 6 - this helped ๐Ÿ˜„
                Jorgensen
                  Didier Bur
                  BTW, your way of calculating (converting from inches2 to m2) areas is quite strange.
                  Try this:
                  $text=Sketchup.format_area object.area
                  Whatever unit the user has set, area (numeric) will be converted to this unit (string) and a ยฒ is added to the text as well ๐Ÿ˜
                  DB
                    Jorgensen
                    Hi All
                    Thanks for your input.
                    @Didier
                    I have tried that - belive me - but I don't no why, but if I do an Object.area on a face that is 1000x1000mm I get an area of 1,550m2 ? And I have setup units in Model Info - strange ???
                    Another problem. If I doubbleclick the mouse I get a 'attaced' text, that keeps the position inside the face, even if I move the sides. This does not happen when using Object.add_text ๐Ÿ˜ž does any know if it is possible to achieve this by script ?
                    What I'm trying to create is a small script that has the function as I have tried to sketch on the attached image. This would be very useful for me when sketching plans ๐Ÿ˜„
                    The next problem - how do I get group names, add listing them inside a group and adding text inside this group - a lot to learn..... ๐Ÿ˜ž
                      Didier Bur
                      Jorgensen,
                      Try attached script.
                      Acces it via context menu, when a single face is selected in the model.
                      It creates a formatted text on a layer "Areas".
                      For the rest, I don't understand exactly what you mean (groups, and so)...
                      txt_area.rb
                      DB
                        Jorgensen
                        Hi Didier
                        I will have a look at the script.
                        What I main by groups. Is, that I have:
                        • a ground level wich is on Layer 00
                        • first floor in layer 01
                        On layer 00 (ground level), I would like a group that contains a 'area group' for each room, Kitchen, livingroom, and so on... .Each areagrop should have the name of the room, so that a script, can update the Text and area.
                        So, in the maingroup on layer 00, holds a text (on layer 0t Text) that says kitchen size ...., and a group named Kitchen (on layer 0A Area, so it can be turned off).
                        A bit dificult to explain ๐Ÿ˜ž
                        Jorgensen
                          Didier Bur
                          OK, I understand.
                          This is doable, but I have not much time to help you by now ๐Ÿ˜ข
                          Remind me...
                          DB
                            Jorgensen
                            Hi Didier
                            Thank - you have allready helped. I'll se what I can fix myself.
                            By the help from this forum, it might be possible ๐Ÿ˜„
                            Jorgensen
                              Jorgensen
                              I have a question about the Sketchup.format_area utility.
                              My model is in mm, but I would like the result to be in m2 not as Sketchup.format_area shows mm2 - is this somehow possible ?
                                Jorgensen
                                Its now going the right way... ๐Ÿ˜„
                                I have one question.
                                I have a group on each level of the building (the levelGroup). Each levelGroup contains a number of groups, that holds info for each room, the area and name. roomGroups.
                                I then doubbleclick, and get inside a levelgroup, and update the roomGroups.
                                To keep track of the roomGroups I use:
                                target = Sketchup.active_model.active_entities;
                                $areaObjects.push target.add_text text, coordinates
                                I then have an array $areaObjects, that cointain all the text added (roomGroups).
                                If I wan't to delete/update all the text, I can read the array again and then erase! them, but this will delete all the text on in all levelGroups.
                                Is there a way to tjek if the roomGroup is inside the active group ?
                                Jorgensen
                                  Didier Bur
                                  Yes:
                                  Switch to meters unit just before the format_area instruction, then switch back to mm:
                                  old_unit=Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                                  Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]=4
                                  then_call_the_format_area_instruction_here
                                  (result is a string so it would'nt be affect by later changes)
                                  Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]=old_unit
                                  (to switch back to mm in your case
                                  DB
                                    Jorgensen
                                    Hi Didier
                                    Thanks for your reply. Just the way I would do, I just could'nt find the settings in Ruby.
                                    One problem however, the text now becomes 14 Meters2 - should be 14 M2 - I guess I'll have to do somekind ereg_replace....
                                    Thanks for your help.
                                    Jorgensen
                                      Jorgensen
                                      Easy area = area.sub("eters ", "") ๐Ÿ˜„
                                      This is fun ๐Ÿ˜
                                        I did an AreaFormat tool a while ago... see: http://www.sketchucation.com/forums/scf/viewtopic.php?p=12808#p12808
                                        It could easily be adjusted to suit your current units if they are not listed...
                                          Jorgensen
                                          Thanks TIG - I'll have a look at it...
                                          Right now I have a problem, actual the last before I can use the script at work...
                                          I use this to tjek and delete objects in the active group:
                                          def tmAreaDelete
                                          objects_active = Sketchup.active_model.active_entities
                                          for object in objects_active
                                          if($areaObjects.include?object)
                                          object.erase! unless object.deleted?
                                          $areaObjects.delete object
                                          What teases me, is I have to run the tmAreaDelete tree times to delete all text objects - and I just can't se why ๐Ÿ˜ž It works if I skip the line '$areaObjects.delete object' but that can't be a good solution.
                                          Jorgensen
                                          1 / 2
