    Text position problem
    23 Posts 5 Posters 3.9k Views 5 Watching
    • Didier BurD
      Didier Bur
      Jorgensen,
      Try attached script.
      Acces it via context menu, when a single face is selected in the model.
      It creates a formatted text on a layer "Areas".
      For the rest, I don't understand exactly what you mean (groups, and so)...
      txt_area.rb
      DB
        Jorgensen
        Hi Didier
        I will have a look at the script.
        What I main by groups. Is, that I have:
        • a ground level wich is on Layer 00
        • first floor in layer 01
        On layer 00 (ground level), I would like a group that contains a 'area group' for each room, Kitchen, livingroom, and so on... .Each areagrop should have the name of the room, so that a script, can update the Text and area.
        So, in the maingroup on layer 00, holds a text (on layer 0t Text) that says kitchen size ...., and a group named Kitchen (on layer 0A Area, so it can be turned off).
        A bit dificult to explain 😞
        Jorgensen
        • Didier BurD
          Didier Bur
          OK, I understand.
          This is doable, but I have not much time to help you by now 😒
          Remind me...
          DB
            Jorgensen
            Hi Didier
            Thank - you have allready helped. I'll se what I can fix myself.
            By the help from this forum, it might be possible πŸ˜„
            Jorgensen
              Jorgensen
              I have a question about the Sketchup.format_area utility.
              My model is in mm, but I would like the result to be in m2 not as Sketchup.format_area shows mm2 - is this somehow possible ?
                Jorgensen
                Its now going the right way... πŸ˜„
                I have one question.
                I have a group on each level of the building (the levelGroup). Each levelGroup contains a number of groups, that holds info for each room, the area and name. roomGroups.
                I then doubbleclick, and get inside a levelgroup, and update the roomGroups.
                To keep track of the roomGroups I use:
                target = Sketchup.active_model.active_entities;
                $areaObjects.push target.add_text text, coordinates
                I then have an array $areaObjects, that cointain all the text added (roomGroups).
                If I wan't to delete/update all the text, I can read the array again and then erase! them, but this will delete all the text on in all levelGroups.
                Is there a way to tjek if the roomGroup is inside the active group ?
                Jorgensen
                • Didier BurD
                  Didier Bur
                  Yes:
                  Switch to meters unit just before the format_area instruction, then switch back to mm:
                  old_unit=Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                  Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]=4
                  then_call_the_format_area_instruction_here
                  (result is a string so it would'nt be affect by later changes)
                  Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]=old_unit
                  (to switch back to mm in your case
                  DB
                    Jorgensen
                    Hi Didier
                    Thanks for your reply. Just the way I would do, I just could'nt find the settings in Ruby.
                    One problem however, the text now becomes 14 Meters2 - should be 14 M2 - I guess I'll have to do somekind ereg_replace....
                    Thanks for your help.
                    Jorgensen
                      Jorgensen
                      Easy area = area.sub("eters ", "") πŸ˜„
                      This is fun 😍
                        I did an AreaFormat tool a while ago... see: http://www.sketchucation.com/forums/scf/viewtopic.php?p=12808#p12808
                        It could easily be adjusted to suit your current units if they are not listed...
                          Jorgensen
                          Thanks TIG - I'll have a look at it...
                          Right now I have a problem, actual the last before I can use the script at work...
                          I use this to tjek and delete objects in the active group:
                          def tmAreaDelete
                          objects_active = Sketchup.active_model.active_entities
                          for object in objects_active
                          if($areaObjects.include?object)
                          object.erase! unless object.deleted?
                          $areaObjects.delete object
                          What teases me, is I have to run the tmAreaDelete tree times to delete all text objects - and I just can't se why 😞 It works if I skip the line '$areaObjects.delete object' but that can't be a good solution.
                          Jorgensen
                            Jorgensen
                            And a other problem:
                            The array $areaObjects, is not saved inside the file - so next time it is loaded - one have to manuel delete all the textobjects and add newones -
                            Is there a smart workaround here ?
                            Jorgensen
                              Jorgensen
                              It seems that I can use
                              model = Sketchup.active_model
                              data = model.get_attribute "TM_area", "textObjects", "default"
                              and
                              value = model.set_attribute "TM_area", "textObjects", objects
                              • daikuD
                                daiku
                                J:
                                You are deleting entities from the active entities list while you are iterating over the same list. In other words, you are scrambling the list whilst travesing it. Don't do that. Collect all your enities into a seperate list. Then interate through that list and delete them. CB.
                                Clark Bremer
                                http://www.northernlightstimberframing.com
