    Confusing method !
    6 Posts 4 Posters 904 Views 4 Watching
    • Didier BurD
      Didier Bur
      Hi all,
      I've coded a method to test if a Point3d lies within a face. This method returns a wrong result sometimes 👿
      class Geom;;Point3d
      def on_face?(f)
        points3d=[]
        f.vertices.each { |v| points3d.push(v.position) }
        i = self.project_to_plane f.plane
        if self.on_plane?(f.plane) and i == self and Geom.point_in_polygon_2D(self,points3d,true)
          puts "in !"
          return true
        else
          puts "out !"
          return false
      As you can see, 3 different tests are made to ensure that the point is on the face and within the boundaries of the face, but this is not working !
      Help anyone ?
      DB
      • A
        azuby
        The first thing I think about is: Calculations with Float type. Maybe in the background.
        azuby
        • daikuD
          daiku
          I needed a "point_on_face" method a while back. I can't remember who gave me this tip, but here it is:
          if face.classify_point(pt) >= 1 and face.classify_point(pt) <= 4 then...
          Clark Bremer
          http://www.northernlightstimberframing.com
          • Didier BurD
            Didier Bur
            Thanx, interesting !
            The doc at classify_point is empty 😡
            DB
            • TIGT
              Todd Burch did something on it a while ago...
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=57&t=2927&p=13928&hilit=face#p13928
              • Didier BurD
                Didier Bur
                Thanx a bunch TIG 👍
                DB
