Confusing method !
Hi all,
I've coded a method to test if a Point3d lies within a face. This method returns a wrong result sometimes
class Geom;;Point3d def on_face?(f) points3d=[] f.vertices.each { |v| points3d.push(v.position) } i = self.project_to_plane f.plane if self.on_plane?(f.plane) and i == self and Geom.point_in_polygon_2D(self,points3d,true) puts "in !" return true else puts "out !" return false end endAs you can see, 3 different tests are made to ensure that the point is on the face and within the boundaries of the face, but this is not working !
Help anyone ? -
The first thing I think about is: Calculations with Float type. Maybe in the background.
azuby
I needed a "point_on_face" method a while back. I can't remember who gave me this tip, but here it is:
if face.classify_point(pt) >= 1 and face.classify_point(pt) <= 4 then... -
Thanx, interesting !
The doc at classify_point is empty
Todd Burch did something on it a while ago...
http://www.sketchucation.com/forums/scf/viewtopic.php?f=57&t=2927&p=13928&hilit=face#p13928
Thanx a bunch TIG
