    Greetings and a Question
    Scheduled Pinned Locked Moved Google Earth
    5 Posts 3 Posters 4.8k Views 3 Watching
    • M
      M_Woodworth
      I've been learning and using SketchUp for a while and recently have been experiencing problems uploading to 3D Warehouse. When I try to upload from SU6 I get the spinning beach ball of death. 😒 If I try to upload from SU5 Pro I've been getting an "Invalid Request" screen. It used to work but this seems to have happened since I upgraded to Leopard. Anyone know of a bug or a fix? I've tried someone's suggestion of converting to a GoogleEarth kmz file, still no luck. Is there perhaps a "preference" like file that needs to be trashed and/or reset? Do I need to uninstall and reinstall everything? πŸ’­
      Any help is appreciated. I would like to share more models in the warehouse but can't!
      Thanks, Maurice.
      Mac G5 tower 2Ghz(dual), 2.5GB RAM, OS Leopard 10.5.1
      SketchUp 5 Pro (5.0.262)
      SketchUp 6.0 (6.4.120)
      • GaieusG
        Hi Maurice,
        Yes, there is a known issue currently with Leopard and uploading to the WareHouse (this will hopefully be resolved soon). Until then there is a workaround provided you would like to upload to Google Earth and not particularly the skp model.
        • save (i.e. expport) your modell to kmz format
        • go to the warehouse in your preferred browser
        • upload the file from there (you can only upload kmz files this way - so not for SU but only for GE)
        • you can also attach a "thumbnail" to your model (however as far as I know it must be smaller than the "usual" preview window of the model).
        • M
          M_Woodworth
          Thank you Gaieus, I appreciate the answer. I've tried the Google Earth upload option and it didn't work for me either. I'll try and be patient and wait for the fix.
          Cheers,
          Maurice
          • A
            alan wood
            Hi Maurice,
            Welcome to this forum
            cheers,
            Alan
            • M
              M_Woodworth
              Thank you Alan. I'm sure there will be tons of good info here.
              Cheers,
              Maurice
