    Measure Pitch
    6 Posts 4 Posters 2.5k Views 4 Watching
    • S
      seasdes
      Is there an easy way to measure the pitch of an inclined plane in SU6 (eg. roof face)?
      Walter
      Using Sketchup Pro 2019
      • DanielD
        Daniel
        If you mean measure an existing model, the only way I know is to use guides: create a vertical guideline from a point, then copy it 12" horizontally, then create a horizontal guideline at the intersection between the inclided plane and one of the vertical guides; then measure the vertical distance.
        If you mean measure the pitch of a roof you are modeling, use the compass tool - instead of entering a value for the angle, enter the pitch (such as 7:12).
        My avatar is an anachronism.
        • Jean LemireJ
          Jean Lemire
          Hi folks.
          See attached SU file for ideas.
          Roof pitch measure.skp
          • S
            seasdes
            Hi All
            My question was directed to measuring the pitch of existing roofs etc. I find myself measuring these pitches (degrees) quite often and do not always vave gable roofs. I was hoping that there was a magic script that may be able to measure the angle of such faces.
            Walter
            • Jean LemireJ
              Jean Lemire
              Hi Walter, hi folks.
              If the measuring protractor cannot measure the angle you want, can you post a picture (sketch) of what you want to acheive. I am pretty sure that some trick can be found to do the job.
              • C
                Charlie__V
                Walter,
                I do not posses a magic script (ruby).....But I can offer a Speed Square.
                Yeah I know.....not what your after.....but in the mean time give it a try.
                And if you have never used one before, it's pretty straight forward(see attached).
                Using the speed square component,align the pivot pt and rotate until vertical or horizontal.(maybe a bit oversimplifying... I know).
                Oh, and you mention hip roofs, if working with a model just use the cross section tool & the speed square as above. :~)
                Best,
                Charlie
                SPEEDSQUARE APPLIED.zip
