Building a cannon
So, i'm trying to build a cannon. now it rotates with a servo joint. i wonder if it's possible to throw out the ball with a piston joint after the cannon is rotated.
Thank you in advance.
A piston would certainly push the ball out. I don't know how you would trigger it tho. Maybe a hidden object that will hold it in until its in the right position.
so, basically, i cannot make the piston joint rotate along with the cannon and fire when i want...
The piston will rotate with the cannon. But it will fling the cannon ball as soon as you play the simulation.
thank you so much! i finally got what i wanted!
can i ask you one more thing? is it possible to make the cannon rotate on the blue axis with a wheel+servo joint?
im not a sketchy physics user, but cant you rotate the modle to one side, apply the joint and then rotate it back? i just saw it on a vid, so mght well be wrong.
I had to explode and re-group the wooden parts. It was messed up somehow.
now it works perfectly! thanks!
have a look at the completed model!
Check out this cannon that I made. It's self moving and quite realistic. Different reloading mechanism, hope it's intuitive.
nice! it's very powerful, though i found quite hard to understand how it fires...
Maybe you can fire some flowers and it will be perfect
Very cool engine
Showing hidden geometry and turning on transparency will reveal all secrets of the cannon.
at last...
[flash=425,355:3n7imfcw]http://www.youtube.com/v/DoVzTrK3NGc[/flash:3n7imfcw]
Register LoginAdvertisement
