    Building a cannon
    14 Posts 5 Posters 3.2k Views 5 Watching
      Julius
      thank you so much! i finally got what i wanted!
      can i ask you one more thing? is it possible to make the cannon rotate on the blue axis with a wheel+servo joint?
      Cannon.skp
        remus
        im not a sketchy physics user, but cant you rotate the modle to one side, apply the joint and then rotate it back? i just saw it on a vid, so mght well be wrong.
          CPhillips
          I had to explode and re-group the wooden parts. It was messed up somehow.
          Cannon-5.skp
            Julius
            now it works perfectly! thanks!
              Julius
              have a look at the completed model!
                architectboy
                Check out this cannon that I made. It's self moving and quite realistic. Different reloading mechanism, hope it's intuitive.
                Cannon.skp
                  Julius
                  nice! it's very powerful, though i found quite hard to understand how it fires...
                    Maybe you can fire some flowers and it will be perfect πŸ˜‰ 😎
                    Very cool engine πŸ‘
                      architectboy
                      Showing hidden geometry and turning on transparency will reveal all secrets of the cannon.
                        Julius
                        at last...
                        [flash=425,355:3n7imfcw]http://www.youtube.com/v/DoVzTrK3NGc[/flash:3n7imfcw]
