    Building a cannon
    14 Posts 5 Posters 3.1k Views 5 Watching
      Julius
      So, i'm trying to build a cannon. now it rotates with a servo joint. i wonder if it's possible to throw out the ball with a piston joint after the cannon is rotated.
      Thank you in advance.
      Cannon.skp
        CPhillips
        A piston would certainly push the ball out. I don't know how you would trigger it tho. Maybe a hidden object that will hold it in until its in the right position.
          Julius
          so, basically, i cannot make the piston joint rotate along with the cannon and fire when i want...
            CPhillips
            The piston will rotate with the cannon. But it will fling the cannon ball as soon as you play the simulation.
            Cannon-2.skp
              Julius
              thank you so much! i finally got what i wanted!
              can i ask you one more thing? is it possible to make the cannon rotate on the blue axis with a wheel+servo joint?
              Cannon.skp
                remus
                im not a sketchy physics user, but cant you rotate the modle to one side, apply the joint and then rotate it back? i just saw it on a vid, so mght well be wrong.
                  CPhillips
                  I had to explode and re-group the wooden parts. It was messed up somehow.
                  Cannon-5.skp
                    Julius
                    now it works perfectly! thanks!
                      Julius
                      have a look at the completed model!
                        architectboy
                        Check out this cannon that I made. It's self moving and quite realistic. Different reloading mechanism, hope it's intuitive.
                        Cannon.skp
                          Julius
                          nice! it's very powerful, though i found quite hard to understand how it fires...
                            Maybe you can fire some flowers and it will be perfect πŸ˜‰ 😎
                            Very cool engine πŸ‘
                              architectboy
                              Showing hidden geometry and turning on transparency will reveal all secrets of the cannon.
                                Julius
                                at last...
                                [flash=425,355:3n7imfcw]http://www.youtube.com/v/DoVzTrK3NGc[/flash:3n7imfcw]
