    Text editing
    5 Posts 3 Posters 970 Views 3 Watching
      alan wood
      Greeting all
      I wish to add leader text to a model and thats no problem.
      I'm writing for a woodworking magazine and I'm providing the editor with jpg images of my models.
      What he is requesting when it comes to text is for me to provide a model with the arrow pointing to the part of the image i am refering to, BUT WITHOUT THE TEXT.
      I've searched the forum for a solution with no luck.
      thanks in anticipation.
      Alan.
        Hi Alan, hit a space and two enters.
          alan wood
          Hi Gaieus,
          Thank you very much indeed for that.
          cheers
          Alan 😍
          • Jean LemireJ Offline
            Jean Lemire
            Hi folks.
            I also use this trick with dimensions to get an line with an arrow at each end to illustrate aligments for example. I edit the dimension text and use a simple space for it.
            To avoid a break in the dimension line, I use an "outside" or "above" alignment instead of the "centered" alignment. Use Menu Window --> Model Info --> Dimensions.
            Just ideas.
              alan wood
              Jean
              thanks for that. In fact that was also a request from the editor.
              cheers
              Alan πŸ˜„ πŸ˜„ πŸ˜„
