    Shadows bug
    4 Posts 2 Posters 1.1k Views 2 Watching
    • VLADIMIRZMV Offline
      VLADIMIRZM
      hi.
      well my english is bad...
      i have a model at 0N and 0E becuase this way i can set up shadows easily (technical shadows 45º,30º...) or just more precision in shadows control.
      but when i set up an hour X and update de scene, some time this escene don't updates at all and it happens always if i reopen the file, and the shadows box shows correct time.
      see my attach and look the time: 3pm but it's wrong, i have to change 1 minute and return 1 minute to get right shadows, but again if update close and open the problem continues. this is for most of my archives.
      photo ok
      photo bug
      file
        Hi Vladimir,
        I downloaded your file and played with it a little bit. Try this, please:
        • In the scene manager (Window menu > Scenes) make sure that "Shadow settings" is checked.
        • When you change some shadow setting in a scene, make sure to right click on the scene tab and "Update".
        • Create a couple of scenes (but without moving your view) to check out if it works.
          VLADIMIRZM
          hello Gaieus and thanks by your answer.
          I've tried this method too and I'm afraid it doesn't work even throug different pcs.
            I tried with your model and it seemed to work for me.
