    Make_component_bug
    1 Posts 1 Posters 821 Views 1 Watching
      rhankc
      I think there is a fault in the Make Component command. 9 out of 10 times when I make a 4 line rectangle and make that box a component, in the proximity of other geometry (touching even just one edge) i have to erase a line to be able to edit the new component, Then i have to retrace an edge to skin the rectangle again. otherwise I just left click and right click on the edge and the MAKE component menu keeps coming up. This shows up in other areas also. When you have a wall face, and draw a window or door on the face of the wall, no matter how you select the lines to make the component, there are lines under/over the made component that must be dealt with first.
      It behaves as if you did an Intersect With command and it intersects screen space and makes entities,
      Hank
