    🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Component Spray Tool released
    30 Posts 18 Posters 5.3k Views 18 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      I think it's time to release the first version of my new toy: the Component Spray Tool.
      Go here to download: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=4571
      Options:
      • 8 Spray shapes: Point, line, triangle, square, rectangle, circle, spray, selection
      • Spray pressure
      • Random rotate
      • Prevent stacking
      • Keep vertical
      • Maintain proportions
      • Low and high scale values, mirroring
      • Low and high steepness constraint
      • Low and high altitude constraint
      Remember that it is a first release, it may contain bugs (however nothing to harm your computer 😉 )
      Please comment and report if you find it useful...
      DB
        Wow! Late Christmas presents!
        Within an hour, at home, I'll be spraying components eveywhere in SU! Great, thanks, Didier!
        • I Offline
          ilay7k
          Great!!!
          Thanks!
            tomsdesk
            This is just wonderful...thanks a bunch!
            2.5D Trees & Shrubs!
            • jujuJ Offline
              juju
              Thx man!
              I see the ruby name (fr_compo_spray.rb) has the "fr" in front which you usually use for your French language scripts, is this one French only or is there an English version as well?
                Hey Juju, the top zip file contains the English version, too.
                  a4chitect
                  very nice coding, thanks didier!!!
                  • EdsonE Offline
                    Edson
                    didier,
                    one more great script! have you noticed it is not possible to print the pdf that comes with it? it requires a password for that.
                    regards,
                    http://www.mahfuz.arq.br
                    • PixeroP Offline
                      Pixero
                      First quick test looks really great. Thanks!
                      • F Offline
                        farukahmet
                        Been away from the SU community for a long time now, so yesterday I decided to check if there was any new toys around and saw this one: It definitely looks, and works great!
                        Good work as usual, Didier...and nice guide too.
                          richcat
                          Hi Didier,
                          Just got some time to try out this ruby, but I got following error message?
                          • K Offline
                            kwistenbiebel
                            Ouch I missed this thread....
                            I have got to try it out. Sounds really good.
                              Didier Bur
                              @ Richcat: 😲 😲
                              I don't see any reason to get this message if you are using the same version as other users. This let me think that this has something to do with some of your other scripts ?
                              DB
                                richcat
                                Thanks Didier for putting me on the right track.
                                I kept removing a ruby until it ran without errors, it turns out to be a old RPS one for CDoc_loader for reference, which is no longer used and has been integrated into RP tools now.
                                Again thanks for your help 😍
                                  Didier Bur
                                  Frightening avatar BTW 😮
                                  DB
                                  • sk.lionS Offline
                                    sk.lion
                                    wow, this will be great to create custom landscape for major projects, bravo 👍
                                      lapx
                                      Fantasitc script DB! Tip to those trying out for the first time.
                                      You must have a plane or surface below to get results. 😍
                                      • StinkieS Offline
                                        Stinkie
                                        Just tried it. Very, very nice. Thanks!
                                        • K Offline
                                          kwistenbiebel
                                          I just read the .pdf tutorial on this plugin.
                                          It is just unbelievable what this thing can do.
                                          Thanks again Didier.
                                            "Instancing" within SU, isn't it? 😉
                                            • 1 / 2
