๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Component Spray Tool released
30 Posts 18 Posters 5.3k Views
    Didier Bur
    Hi all,
    I think it's time to release the first version of my new toy: the Component Spray Tool.
    Go here to download: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=4571
    Options:
    • 8 Spray shapes: Point, line, triangle, square, rectangle, circle, spray, selection
    • Spray pressure
    • Random rotate
    • Prevent stacking
    • Keep vertical
    • Maintain proportions
    • Low and high scale values, mirroring
    • Low and high steepness constraint
    • Low and high altitude constraint
    Remember that it is a first release, it may contain bugs (however nothing to harm your computer ๐Ÿ˜‰ )
    Please comment and report if you find it useful...
    DB
      Wow! Late Christmas presents!
      Within an hour, at home, I'll be spraying components eveywhere in SU! Great, thanks, Didier!
      • I Offline
        ilay7k
        Great!!!
          tomsdesk
          This is just wonderful...thanks a bunch!
          2.5D Trees & Shrubs!
            juju
            Thx man!
            I see the ruby name (fr_compo_spray.rb) has the "fr" in front which you usually use for your French language scripts, is this one French only or is there an English version as well?
              Hey Juju, the top zip file contains the English version, too.
                a4chitect
                very nice coding, thanks didier!!!
                • E Offline
                  Edson
                  didier,
                  one more great script! have you noticed it is not possible to print the pdf that comes with it? it requires a password for that.
                  regards,
                  edson mahfuz, architect| porto alegre โ€ข brasil
                  http://www.mahfuz.arq.br
                    Pixero
                    First quick test looks really great. Thanks!
                    • F Offline
                      farukahmet
                      Been away from the SU community for a long time now, so yesterday I decided to check if there was any new toys around and saw this one: It definitely looks, and works great!
                      Good work as usual, Didier...and nice guide too.
                        richcat
                        Hi Didier,
                        Just got some time to try out this ruby, but I got following error message?
                          kwistenbiebel
                          Ouch I missed this thread....
                          I have got to try it out. Sounds really good.
                            Didier Bur
                            @ Richcat: ๐Ÿ˜ฒ ๐Ÿ˜ฒ
                            I don't see any reason to get this message if you are using the same version as other users. This let me think that this has something to do with some of your other scripts ?
                            DB
                              richcat
                              Thanks Didier for putting me on the right track.
                              I kept removing a ruby until it ran without errors, it turns out to be a old RPS one for CDoc_loader for reference, which is no longer used and has been integrated into RP tools now.
                              Again thanks for your help ๐Ÿ˜
                                Didier Bur
                                Frightening avatar BTW ๐Ÿ˜ฎ
                                DB
                                • sk.lionS Offline
                                  sk.lion
                                  wow, this will be great to create custom landscape for major projects, bravo ๐Ÿ‘
                                    lapx
                                    Fantasitc script DB! Tip to those trying out for the first time.
                                    You must have a plane or surface below to get results. ๐Ÿ˜
                                    • StinkieS Offline
                                      Stinkie
                                      Just tried it. Very, very nice. Thanks!
                                        kwistenbiebel
                                        I just read the .pdf tutorial on this plugin.
                                        It is just unbelievable what this thing can do.
                                        Thanks again Didier.
                                          "Instancing" within SU, isn't it? ๐Ÿ˜‰
