    Section Cut Width
    5 Posts 3 Posters 1.1k Views 3 Watching
    • R
      rhankc
      Hello,
      I have a basic question that I dont have a clue as to where the answer may be, so i need to ask you guys.
      Under the Styles menu > Edit , there is a box with a number in it called Section Cut Width. Can someone explain where this is important and what it is? many thanks
      Hank
      • boofredlayB
        boofredlay
        It is the line width displayed by a section cut. It is independent of the profiles setting. This way you can have a heavy cut line with your section while the rest of the model is fine lines or visa versa.
        Try it out.
        • boofredlayB
          boofredlay
          Like these.
          First one is with the width at 1 and the second at 6.
          • R
            rhankc
            OK cool, i hope this will help with some line weight issues. occasionally I get a section cut that has real heavy lines when printed. Must be one of the styles with a high value. But if I do a section cut with a high value and group a section slice and overlay it, I should get a strong outline where needed.
            Thanksalot
            Hank
            • B
              Bill Wilson
              😍 Thanks for that Eric, it is not just the asker of the question that requires the information. 😍 Thank you for being you.
              Cheers to all,
              Bill.
              PS And thank you Hank for asking β˜€
