    Anyone uses AutoCAD LT 2008?
    5 Posts 4 Posters 590 Views 4 Watching
      lrsuser
      Hello all!
      Can AutoCAD LT 2008 open an AutoCAD 2008 file?
        Stu
        My guess is that it would have too.
        The two have always had a pretty close fit.
        http://www.landesign.com.au
        • jujuJ Offline
          juju
          I'm no AutoCAD monkey, but AFAIK the LT version is completely compatible with the regular version (file saving characteristics wise), where it differs is the functionality of the program itself is a lot less in the LT version.
          • AnssiA Offline
            Anssi
            The general idea is that LT can open "full" files. The main difference between the two is that LT has almost none 3D tools, it cannot display images, and that it has no programming interfaces (like AutoLisp or ARX) It is a bit different for DWG files created with the AutoCad Architecture 2008 or similar Autodesk variants. The special AEC objects created by these need an "enabler" to be run to be visible in normal AutoCad, and I don't think that LT can run these.
            Anssi
              lrsuser
              thank you for the response. I'll fiddle with the trial version of LT over the weekend.
