    High School Roller Coaster Modeling Project
    13 Posts 4 Posters 4.7k Views 4 Watching
    • G
      GreenToaster
      Hello,
      I'm a bit unsure where would be the best forum to post this . . . ?
      Anyway, I'm going to give my high school students a project:
      • research roller coasters (done)
      • design roller coaster using SketchUp (what else)
      • build a model using fan fold foam*, popsicle sticks & hot glue
      • create SU model of the actual coaster built
      • report of what was anticipated, accomplished, learned
      I have quickly put together some basic guidelines - surely these rules need to be altered. I wanted them to work in groups of 3. I was thinking of the following time restrictions (because some students would take six months to do this if allowed):
      3 hours for creating the preliminary CAD model
      4 1/2 hours to build the roller coaster
      2 hoursto create the CAD model of what was built
      1 hour to evaluate the models and follow up with what's been learned
      %(#004080)[The Rules:
      1 - Each group may select from one of three different roller coaster designs:
      _Looping coaster --> Maximum points = 200/200
      _Jumping coaster --> Maximum points = 190/200
      _Distance coaster --> Maximum points = 180/200
      2 - Only the car provided by the instructor may be used with this project
      3 - Any coaster which is not complete by the time period will receive a percentage grade for construction and CAD modeling - performance grade will equal zero
      4 - Each roller coaster must have a 2" x 3" horizontal platform at the top
      5 - Each roller coaster must be free standing - two textbooks are allowed
      in construction but cannot be glued or damaged in any way
      6 - total materials: 20 popsicle sticks, two sheets of ~24" x ~48" 0.22
      pink foam insulation, "reasonable" amount of glue sticks
      7 - Project is worth from 180 to 200 points:
       7.1 - CAD model of proposed roller coaster = 40 points
       7.2 - Construction of roller coaster =  50 points
      Coaster is within dimension guidelines? 20 points
      Coaster is freestanding?  20 points
      Construction is neat?  10 points
      *** Note:  excessive violations of these criteria will result in zero points earned, for example, if the roller coaster was only 20 inches tall the construction points would equal zero.
       7.3 - CAD Model of constructed roller coaster   =   60 points
      Accurately includes all parts of coaster?  30 points
      Dimensions are correct?  30 points
       7.4 - Roller coaster performance    =  30 to 50 points
      _Looping coaster - maximum = 50 performance points
      	___Did car remain on the coaster?  20 points
      	___Did the car make the loop successfully? 30 points
      _Jumping coaster - maximum = 40 performance points
      	___Did the car clear the gap and remain on the coaster? --> 40 points
      _Distance coaster - maximum = 30 performance points
      	___Distance car coasted from end of coaster = 60" --> 30 points
      	___Distance car coasted from end of coaster = 48" --> 20 points
      	___Distance car coasted from end of coaster = 36" --> 10 points]
      The illustrations are simply to convey concept and illustrate dimension constraints - I don't want to give them too many ideas.
      Any suggestions for making this a successful project will be most appreciated! ๐Ÿ˜„
      If you really want something you won't ever stop pursuing it.
        3eighty
        Have some fun...Make the jump through the loop... ๐Ÿ˜„
        • GaieusG
          Brad, don't give me this, please. I've been through a loop already but I cannot imagine I'd sit on anything that "jumps". That's crazy! Do you, dudes, have that in reality (really)??? ๐Ÿ˜ฎ ๐Ÿ˜ฒ
          • G
            GreenToaster
            No, like the Hot Wheels cars on a flexible plastic track - the Hot Wheels cars are pretty small, about 2 inches long?
            • tinanneT
              tinanne
              How about a little SketchyPhysics added to the schedule? That would be cool!!!
              Executive Director : American Society of Architectural Illustrators
              AIP 30 Competition opens soon. ASAI.org
              Architectural Rendering
              • G
                GreenToaster
                Absolutely! SketchyPhysics will be part of it - I just have to figure out a little more about it. We already began learning about speed - the first of ten lessons which deal with roller coaster physics (attached below - my subscripts and delta symbols aren't displayed here, sorry). This may seem over-simple and ridiculous to be covering such a basic topic in high school, but many are surprised (including myself) how little these folks know about basic math, physics, et cetera:
                %(#000080)[Understanding the Physics of Roller Coasters
                speed = distance / time
                if you travel distance s in a time t, your speed v is
                v = s / t
                The variable v really stands for velocity
                True velocity has a direction associated with it (which speed does not) therefore velocity is a vector. Vectors have both a magnitude and a direction, so with velocity you not only know how fast youโ€™re going, but also in what direction.
                Speed is only a magnitude, so itโ€™s represented with a v (not in bold).
                v = ๏ฒx / ๏ฒt = (xf โ€“ xo) / (tf โ€“ to)
                ๏ฒ = change
                xf = final position
                xo = origin or starting point
                tf = final time
                tO = start time
                v = average speed (supposed to be a hyphen over the "v" - write that in before printing or find the symbol)]
                • G
                  GreenToaster
                  . . . btw, does anyone know of a Ruby script that easily & reliably creates helical curves . . . ? . . .
                  Thanks,
                  Brad
                  • GaieusG
                    There are two "drawhelix.rb"s here.
                    I think I use the later version.
                    • G
                      GreenToaster
                      MEGA-THANKS!!! Works great - I updated the loop drawing above.
                      • G
                        GreenToaster
                        . . . more options . . . food to inspire them rather than feed . . .
                        • GaieusG
                          Now Brad with this latter, helical ramp the problem will be that the cars wil fly off. The path should be slanted inwards a bit I guess. ๐Ÿ˜„
                          Nice ones though!
                          • G
                            GreenToaster
                            Yes - a good learning experience if they fall off - then the question & learning takes place: What was anticipated, how did it perform, what could have been done better?
                            • G
                              GreenToaster
                              The roller coaster project is officially "over" - it was a gigantic success!
                              Sorry this photo is very poor quality but it gives you an idea what some of the students did. This photo does not show all the roller coasters. Only four groups attempted the Round & Round - it was the most difficult, I think.
