    Idea for ruby to reduce file size
    11 Posts 5 Posters 2.5k Views 5 Watching
      sketchy
      Disclaimer: I have no knowledge of Ruby scripting or what its capabilities are. But I had an idea that I thought I would share in case someone with more talent than myself was interested in kicking the idea around a little.
      Like many SU users I mostly model houses and other "built" structures. I make use of groups and components extensively. I do this for organization and to reduce file size.
      I noticed that many of my components or groups have some type of symmetry and could therefore be made up of multiple subcomponents rotated or mirrored about an axis or plane.
      Some of the Google components demonstrate this idea:radial symmetry in table.jpg
      But I immagine that for most people, including myself, it is unintuitive to model a quarter of a table and then rotate it. I model the table and then I move on. I don't take time to explode the table, make a component of 1/4 of it, then rotate it around and regroup.
      What about a ruby that would go into groups and components look for symmetry. If found it would create a component out of 1/4 (or whatever), rotate it around and delete the rest. A cylinder with 100 sides could be one poly rotated around the center point.
      Here is a link I found that has a nice flow chart for determining symmetry:
      http://www.artlandia.com/products/SymmetryWorks/tutorials/classification.html
      It seems like there would be alot of polygons that could be eliminated. Would this help with reducing animation times as well?
      So what do you ruby guys think, is this possible to do?
        SchreiberBike
        I do this a lot as small file sizes are necessary to keep things moving on my slow pc. It works, but there is a downside. You can't "smooth" a line between components. You can only hide it. That means the shading/rendering engine doesn't recognize that there is a continuous surface and it doesn't look as good as it could.
        Still a good idea, but not one you'd want to always use.
          Sketchy, you're right. This is a good way to help reduce file size. It would be kind of neat if this could be automated, too. John does make a good point about applying materials to components in which that has been done so caution should be exercised.
            Hi guys,
            Have a look at the attached file. If you "slice" your object (this case a circle) at its midpoints rather than at the endpoints, you can "keep" it seamless (using the good old techniques - hiding edges etc...).
            SeamlessCylinder.skp
              Gai, you beat me too it. I was about to post an example showing that. It's a good tip.
                Yeah, Dave, but in your other topic I realised that texture mappung is almost impossible this way...
                  sketchy
                  Yup Gai thats exactly what I was thinking. Does this method solve the rendering issue SchreiberBike brought up?
                  And my fantasy involved an automated ruby that would to through every group/component and regroup based on symmetry. Or you could select specific groups/components. I would probably only do the whole model before sending it to LayOut, to someone via email, or posting it on a cool message board with file size limitations πŸ˜„ . I would keep a copy of the unmodified version as well.
                    Sketchy, Gai's method only partly helps with the rendering thing. You won't get a hard edge as you would by hiding a corner but textures would still have a problem. Imagine a tiled top on your table example. It would look like it was cut into pie-shaped segments with the tile cut on an angle. For some things like wood grain textures, you could get a look of a typical veneered top, so sometimes it could be good.
                      Yup, here is an example with different transitions of soft shadows (still the "original", low poly model).
                      Note that the "hardest" shadow edge is neither at a midpoint nor at an endpoint. This is not textured though - just the "clay" model (with the original Front Face) rendered in Kerky.
                      http://www.sketchucation.com/forums/scf/sas/Gallery/Gai/SeamlessCylinder.png
                        sketchy
                        Thanks for the render Gai.
                        For the sake of discussion here are the two models with textures applied. I didn't take any time to scale or move any of the textures.table with tile.jpgcylinder with wood.jpg
                        Here I took the tile texture and moved it slightly (no rotation or scaling). A pretty easy shift. I do recognize that other textures would be more problematic.table with tile2.jpg
                        • X Offline
                          xtrude
                          Hi Sketchy,
                          Did you progress this idea at all? I'm looking for a automated process for splitting a large urban model into individual tiles.
                          Cheers
