    [Plugin] Layer Manager New Release
    66 Posts 34 Posters 71.0k Views 34 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      This is version 2 of my Layer Manager for SU6 (free and Pro).
      What's new:
      · Undo for all commands
      · 2 new commands that deal with current layer
      · 3 new commands to filter the layers visibility 😉
      · 2 new commands to save/load states to/from external files
      · Enhanced display of state dialog box
      · Numerous bugs fixes 😳
      · New icons
      · Active layer setting added
      · "Delete all" layers states option added
      · Overwrite existing states (while loading) option added
      · Restore "Show only" and "Append" added
      Enjoy, ❗
      PATCHED on 12.06.07 6pm to fix a load bug.
      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=layer_manager
      Version française. Decompresser dans le dossier Plugins de SketchUp. Lire la doc PDF incluse SVP.
      Mis à jour le 05.12.07 !
      English version. Unzip in Plugins folder. Read the PDF doc.
      PATCHED on 12.06.07 !
      DB
      • EdsonE Offline
        Edson
        didier,
        this is a fantastic script. thanks for your genius and generosity. and the documentation that comes with it is an example to be followed.
        i have installed it and have started using it right away.
        regards,
        http://www.mahfuz.arq.br
        • Y Offline
          yaza
          Architecte enseignant aussi, mon outil de predilection etant SU et Podium, j'ai laisse aux autres les divers autocad revit et archicad.
          Un grand merci, je me demandais s'il n'etait pas possible de povoir gerer les layers a la facon de archicad. Tu l'as fais. Bravo 👍 😍 👍 😍 👍 😍
          • kenK Offline
            ken
            Didier Bur
            I know you want to protect your work, and I certainly agree with that position, but did you mean to make the PDF file unprintable? I have a note book filled with directions on using scripts, and this particular script will not print.
            Thanks for the script and thanks in advance for your reply.
            Ken
            • Mike LuceyM Offline
              Mike Lucey
              Thanks Didier, just what I needed. This is fantastic 😍
              Mike
                Didier Bur
                Hi Ken,
                Discussed before, and solved here:
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=57&t=2809&p=14105&hilit=layer+manager#p14105
                DB
                • kenK Offline
                  ken
                  Didier
                  Thanks for the quick reply and the printable directions.
                  Ken
                    russellbeta
                    Hey didier, first of all great work! it really saves me alot of time.
                    I have many groups within groups within groups in a model I'm working on, is there a way to move a selection to current layer that digs into groups/subgroups and moves every line/face along with it?
                    this would save me a whole lot of tedious work.
                    thanks again for the freeware.
                      Didier Bur
                      No... 😳 But you may take a look at TIG's defaults2layers.rb recently published. It can help you a bit.
                      Regards,
                      DB
                      • EdsonE Offline
                        Edson
                        Regards,
                        didier,
                        where is it to be found? i could not find here nor at your site. are you sure it has been released by TIG?
                        • JClementsJ Offline
                          JClements
                          try this for Hidden2Layer version 1.2:
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6870
                          • EdsonE Offline
                            Edson
                            thanks, john. i have not gotten used to the indexes yet...
                              GhossbGood
                              Thank's Didier,
                              It's very helpfull for me
                              • Z Offline
                                zed252000
                                "Good Ruby,"
                                "That will Do" 2x
                                Whatever we IMAGINE....
                                  banhdau
                                  thanks
                                  • Bob JamesB Offline
                                    Bob James
                                    Curious problem on my Macs (work and home): The Layer Manager toolbar does not appear automatically. Each time I open SU7 I have to go to View/Tool Palettes and click on Layer Manager. Sort of a nuisance, but Layer Manager is a major player for me in SU.
                                    Is this normal or do I have a problem? ❓
                                      banhdau
                                      thanks
                                      • X Offline
                                        xrok1
                                        can someone post a screenshot or two of this layer manager. i'd like to see it before i decide whether to rearrange my toolbars.
                                          Bob James
                                          Layer Manager is one of my top-usage plug-ins: especially the "all layers invisible except current" (the one with the red dot) and "all layers visible" (the one with the green dot).
                                          Didier has just released a new version that "remembers" the state of the toolbar so you don't have to keep opening it.
                                          Very useful (at least for me).
                                          • takesh hT Offline
                                            takesh h
                                            Really? ☀ Do you care to share where I can get it from?
                                            • 3 / 4
