    Help me! (Arc surface with round over corner)
    3 Posts 3 Posters 808 Views 3 Watching
    • X Offline
      xupacabra
      I'm working on a shelf in here.
      Not to mention that the it was a nightmare to define my "dado joints" (grooves on the arched surface) I'm now trying to fine tune the piece but finished up with an open corner.
      Is there any way (quick or not) to fix the open void?
      I thank you in advance!
      cl_shelf.skp
        AndriyG81
        Is this what you are trying to achieve?
        Look in the attachment
        likethat.skp
        http://andriyg.com
          yet another version (see attached).
          Note that this seems to be a perfect example of the only exception when you should not work in scale 1:1. SU tends to "miss" some small faces when already working in millimetres (1/16 inches). This is especially true when using the follow me and intersect tools (they would end up with really small faces sometimes).
          Also, the follow me tool has some glitches when following arcs (it tends to draw/create the faces perpendicular to the arc and therefore leaving you with some overextruded shapes).
          cl_shelf_G.skp
