    Pulling a corner
    11 Posts 8 Posters 1.6k Views 8 Watching
    • U Offline
      UnclePaul
      Hi all,
      Can you please tell me how to raise just one corner of a cube keeping the top face in the same plane?
      Ta
        sorgesu
        Not mathematically possible. If you are trying to create a sloped flat top surface, there are a number of ways to achieve that. If you are dealing with a perfect cube, you could move one corner up a specific distance, accept the break in the plane temporarily. Then move the opposite corner down the same distance as you moved the other up, and then this will create a flat face and you will be able to remove the diagonal line that broke the top surface.
        Otherwise you could just create the box to it's heighest measure, then separately create a surface that is angled/rotated in the direction that you want, group it and move it over your box to line up the high point with one corner of the box and then explode and/or intersect with model and then erase away the extraneous parts of the box.
        Susan Sorger
        Former Seller Hand Rendered Entourage
        Former Canadian Authorized Training Centre, SketchUp
        • U Offline
          UnclePaul
          Thanks for the reply Sorgesu and of course you're right it's not mathematically possible. I should have said that I want one corner to rise while it's opposite along the diagonal stays in place, and the other two corners on the other diagonal rise the correct distance to maintain the plane.
            Rodentpete
            Your best bet would be to make a seperate sloping face at the right angle and intersect it with the cube, otherwise, if you just rotate the top face up you will have to move the highest and lowest corners of the face so they are in line with the corresponding corners of the bottom face.
            • Alan FraserA Offline
              Alan Fraser
              If you find it too difficult to create the intersecting plane at precisely the right angle, you can always do it be simply extending/copying existing edges. The two side lines are simply the central one copied half the length of the diagonal on the top face...then just join and tidy up.
              cube_slice.skp
              3D Figures
                GreyHead
                Here's another version that's pretty simple. Create your cube and make it a component. Draw a square on top and push-pull it up to half the extra height you want (i.e. the height of the two middle corners). Copy/move a second identical block on top. Move three of the corners down to the top of the first block, then you'll find that you can move the center one down to to the top of the cube. Explode the cube and clean up.
                Bob
                cube_slice_2.skp
                • Jean LemireJ Offline
                  Jean Lemire
                  Hi folks.
                  Same as Alan with less geometry.
                  See attached SU file for idea.
                  Cube with slanted top.skp
                    Gidon Yuval
                    Here's another approach.
                    Cutting plane.skp
                    If you don't know where you're going, you're never going to get there.
                      dylan
                      Now that is clever Gidon 😄 A very different approach and one I never thought of.
                      I have not used the inference in that way before with the pencil tool, thanks for the tip.
                      http://dmdarchitecture.co.uk/
                        Jean Lemire
                        Hi Giddon, hi folks.
                        Yes, very clever. You have very well remembered some of the video tutorials on roof construction.
                        Here is a variation on your variation. I took the liberty of using your model to start. This one use the Move Tool and only one line needs erasing.
                        See attached SU file for ideas.
                        Cutting plane 2.skp
                          Gidon Yuval
                          Jean, I'm honored. 👍
                          And that it a very clever trick! I never would have thought of using the move tool.
                          Thanks.
