    Component Spray Tool released
    30 Posts 18 Posters 7.2k Views 18 Watching
      kwistenbiebel
      Ouch I missed this thread....
      I have got to try it out. Sounds really good.
      • Didier BurD Offline
        Didier Bur
        @ Richcat: 😲 😲
        I don't see any reason to get this message if you are using the same version as other users. This let me think that this has something to do with some of your other scripts ?
        DB
          richcat
          Thanks Didier for putting me on the right track.
          I kept removing a ruby until it ran without errors, it turns out to be a old RPS one for CDoc_loader for reference, which is no longer used and has been integrated into RP tools now.
          Again thanks for your help 😍
            Didier Bur
            Frightening avatar BTW 😮
            DB
            • sk.lionS Offline
              sk.lion
              wow, this will be great to create custom landscape for major projects, bravo 👍
                lapx
                Fantasitc script DB! Tip to those trying out for the first time.
                You must have a plane or surface below to get results. 😍
                • StinkieS Offline
                  Stinkie
                  Just tried it. Very, very nice. Thanks!
                    kwistenbiebel
                    I just read the .pdf tutorial on this plugin.
                    It is just unbelievable what this thing can do.
                    Thanks again Didier.
                      "Instancing" within SU, isn't it? 😉
                        kwistenbiebel
                        True, but in Sketchup you will pretty soon face the poly count limit of the software unfortunately.
                        However, combined with the real instancing/proxy ability of Skindigo, the spray tool RULES 😍
                        http://i140.photobucket.com/albums/r3/kwistenbiebel1/totalcarnage.jpg
                        • W Offline
                          Whaat
                          I spent some time playing around with this indredibly useful tool yesterday. Simply outstanding work! Thanks for the effort Didier! 👍 👍
                          • I Offline
                            ilay7k
                            biebel, great...they(sketchupers) are seeking 7 of skipy and can't find it?! 😄))))))
                              Mars Attack 😄
                                Jorgensen
                                @bibiel
                                wooho, how did you create those trees ??
                                  Didier Bur
                                  Is it possible to set the spray density to less than 10% ?
                                  Moved to the to-do list, along with the "layer mask" option.
                                  DB
                                    kwistenbiebel
                                    Didier,
                                    For a large scene, placing trees on hills could use a density of 1%, and gradually increase it by repeating the spraying ('stacking' put to off).
                                    Right now the plugin warns me sometimes that it will take 'more than 12 minutes' to place 987.235.211 components when using 10 %. I'll bet ! 😄 😄
                                    By the way, I just love the spray tool:
                                      kwistenbiebel
                                      Cool, thank you so much.
                                      Another really cool feature would be the ability to spray in 'air' ...
                                      In this way we could easily model a flock of birds in the sky, a school of fish, balloons etc...
                                      That would be awesome.
                                      But I don't want to push it 😄, the plugin is already amazing as it is.
                                      Regards,
                                      kwistenbiebel
                                        MarkoJovanovic
                                        a way to put a real grass...finally
                                          Jorgensen
                                          Hi Didier
                                          I would like to use your 'component spray tool' to add life to my models. For that 'point spray' would be greate.
                                          But the problem is, when I 'spray' inside a bulding, the people I add are placed outside the group and on top of the roof, not inside the building as I would like.
                                          I'm I doing something wrong or is it not possible ?
                                          • 2 / 2
