    Copy camera position
    4 Posts 2 Posters 2.3k Views 2 Watching
      I often have files which contain several options to a project. I set up scenes with the different layers toggles to display different combinations. However, sometimes I need to adjust the camera and I want all the scenes with the different options to have the same camera position.
      Is there a way I can copy the camera position from one scene to another scene so taht I don't have to recreate all the scenes every time I need to adjust the camera?
      • GaieusG
        If you open the scene dialogue (Window menu), you can uncheck the camera position and the camera (viewpoint) won't change over the scenes.
          So when I activate that scene it'll then use the camera viewport of the previous scene?
          • GaieusG
            You should start with these settings because every scene can have its unique settings which is inherited when a new scene is created. So if you already have your scenes, you should do this setting at every scene and update it.
