πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Problems when exporting
13 Posts 3 Posters 1.7k Views 3 Watching
  • F Offline
    FIRE1BULL
    Best,
    Last time i've been trying to export from sketchup to 3DS Max/IrrEdit,
    tough my objects are invisble in both programs...
    The model is also invisible when importing back to SU, i tried
    ".3ds" and ".obj" files, both fail...
    I find it very weird, because it worked for me before...
    These are my settings:
    http://img244.imageshack.us/img244/6741/naamlooscb2.jpg
    (and yes i've got something selected when i try to export)
    Greetz...
    F1B
    EDIT:
    Also tried to export full hierarchy... without succes
      Can you upload the .skb so I can try see if I get the same result?
      • F Offline
        FIRE1BULL
        Ok,
        It's here for download:
        http://www.gtamodding.org/isle1.skb
          Try these, one is SU straight export, the other is Deep exploration conversion.
          404 Not Found
          (rapidshare.com)
          texture maps included (will uv map in max)
          • F Offline
            FIRE1BULL
            Ok, thx man...
            I see the ones you've exported, tough... I don't see the one's i export 😞
            It used to work before when I before, but i recently reinstalled SU and the
            exported files don't work... 😒
            Here's my exported 3ds file:
            http://www.gtamodding.org/isle1.3ds
              Error 404 on that link.
              • F Offline
                FIRE1BULL
                Oops, sorry:
                http://www.gtamodding.org/isle.3ds
                  Strange, as i see yours just fine.
                  Screen shot from DE.
                  http://img227.imageshack.us/img227/5735/image1sn4.jpg
                  • F Offline
                    FIRE1BULL
                    Tough...
                    It's maybe for a new game project i'm starting...
                    Now i've been testing again with 3DS Max... but not in IrrEdit.. and if I can't see it in IrrEdit i won't be able to see it ingame either 😞
                    I've also exported it than from 3DS Max, with no result 😞
                    Let's see of reinstalling SU for the third time will help...
                    404 Not Found
                    (img403.imageshack.us)
                      Your mesh is there, if you notice the poly count, the error is the textures are absent, try texturing the mesh and it will appear.
                      • F Offline
                        FIRE1BULL
                        Hmm...
                        Tried on severall models with several filetypes (jpg, png, bmp)
                        No succes, i've also imported a model of 123.560 poly's, usually
                        it takes some seconds to load the model into the editor, but now it
                        just says the polycount and nothing more 😞
                        EDIT:
                        Tough... it's very very weird... I've done it a hundred times before...
                        now it doesn't work that well...
                        EDIT2:
                        Someone else of the team has tried to put something ingame in the game engine we're going to use, with no succes... the same problem there:
                        Everything fine in 3DS Max...
                        http://img516.imageshack.us/img516/5474/maxgl0.png
                        Also eveyrthing seems to be fine in MeD (Map Editor, mapped on 0.0.0)
                        http://img156.imageshack.us/img156/2681/lookju7.png
                        When teleported to the right location (0.0.0) nothing to see there 😞
                        http://img516.imageshack.us/img516/7491/000mk1.png
                          richcat
                          I know your having trouble with your 3d but there have been problems with 2d in the recent past, and I wonder if its related.
                          Some like me updated Sketchup recently, but somehow installed the free version, even though our computers said it was the pro version, and then I started to get some strange behaviour.
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=6498 , and there is also mention of 3D problems
                          Here is another link I found on 3D export problems.
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=6180
                          • F Offline
                            FIRE1BULL
                            Thx for the help man πŸ˜„
                            Well let's try to get some older installer of SU somewhere... Someone? πŸ˜•
                            Oh i know some place where to...
