    Problems when exporting
    13 Posts 3 Posters 2.1k Views 3 Watching
    • F Offline
      FIRE1BULL
      Best,
      Last time i've been trying to export from sketchup to 3DS Max/IrrEdit,
      tough my objects are invisble in both programs...
      The model is also invisible when importing back to SU, i tried
      ".3ds" and ".obj" files, both fail...
      I find it very weird, because it worked for me before...
      These are my settings:
      http://img244.imageshack.us/img244/6741/naamlooscb2.jpg
      (and yes i've got something selected when i try to export)
      Greetz...
      F1B
      EDIT:
      Also tried to export full hierarchy... without succes
      • soloS Offline
        Can you upload the .skb so I can try see if I get the same result?
        • F Offline
          FIRE1BULL
          Ok,
          It's here for download:
          http://www.gtamodding.org/isle1.skb
          • soloS Offline
            Try these, one is SU straight export, the other is Deep exploration conversion.
            404 Not Found
            (rapidshare.com)
            texture maps included (will uv map in max)
            • F Offline
              FIRE1BULL
              Ok, thx man...
              I see the ones you've exported, tough... I don't see the one's i export 😞
              It used to work before when I before, but i recently reinstalled SU and the
              exported files don't work... 😒
              Here's my exported 3ds file:
              http://www.gtamodding.org/isle1.3ds
              • soloS Offline
                Error 404 on that link.
                • F Offline
                  FIRE1BULL
                  Oops, sorry:
                  http://www.gtamodding.org/isle.3ds
                  • soloS Offline
                    Strange, as i see yours just fine.
                    Screen shot from DE.
                    http://img227.imageshack.us/img227/5735/image1sn4.jpg
                    • F Offline
                      FIRE1BULL
                      Tough...
                      It's maybe for a new game project i'm starting...
                      Now i've been testing again with 3DS Max... but not in IrrEdit.. and if I can't see it in IrrEdit i won't be able to see it ingame either 😞
                      I've also exported it than from 3DS Max, with no result 😞
                      Let's see of reinstalling SU for the third time will help...
                      404 Not Found
                      (img403.imageshack.us)
                      • soloS Offline
                        Your mesh is there, if you notice the poly count, the error is the textures are absent, try texturing the mesh and it will appear.
                        • F Offline
                          FIRE1BULL
                          Hmm...
                          Tried on severall models with several filetypes (jpg, png, bmp)
                          No succes, i've also imported a model of 123.560 poly's, usually
                          it takes some seconds to load the model into the editor, but now it
                          just says the polycount and nothing more 😞
                          EDIT:
                          Tough... it's very very weird... I've done it a hundred times before...
                          now it doesn't work that well...
                          EDIT2:
                          Someone else of the team has tried to put something ingame in the game engine we're going to use, with no succes... the same problem there:
                          Everything fine in 3DS Max...
                          http://img516.imageshack.us/img516/5474/maxgl0.png
                          Also eveyrthing seems to be fine in MeD (Map Editor, mapped on 0.0.0)
                          http://img156.imageshack.us/img156/2681/lookju7.png
                          When teleported to the right location (0.0.0) nothing to see there 😞
                          http://img516.imageshack.us/img516/7491/000mk1.png
                            richcat
                            I know your having trouble with your 3d but there have been problems with 2d in the recent past, and I wonder if its related.
                            Some like me updated Sketchup recently, but somehow installed the free version, even though our computers said it was the pro version, and then I started to get some strange behaviour.
                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=6498, and there is also mention of 3D problems
                            Here is another link I found on 3D export problems.
                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=6180
                            • F Offline
                              FIRE1BULL
                              Thx for the help man πŸ˜„
                              Well let's try to get some older installer of SU somewhere... Someone? πŸ˜•
                              Oh i know some place where to...
