    [Help] Shading on flat surfaces
    17 Posts 4 Posters 2.2k Views 4 Watching
    • V Offline
      Verrou
      I have an object over a flat surface, and shading on the object. But when I render it, the flat surface turns grey, instead of staying clean white which I need, can anyone tell me how to keep it white?
      Thanks.
        At least an image would be good for us to see whet's the issue.
        • V Offline
          Verrou
          Sorry, here you go:
          http://img401.imageshack.us/img401/4749/imageep3.png
          See how the white surface has gone grey?
            remus
            do you need the surface at all? SU should cast shadows straight onto the ground plane, if that's the effect your looking for.
            • V Offline
              Verrou
              But now the ground plane is grey -.-
              http://img149.imageshack.us/img149/4389/imagerl6.png
              • boofredlayB Offline
                boofredlay
                Turn your ground off in your styles and change your background to white.
                You will still be able to cast a shadow on the ground plane. πŸ˜‰
                • V Offline
                  Verrou
                  Mine doesn't render shadows 😞
                  http://img295.imageshack.us/img295/4546/imagebw4.png
                    boofredlay
                    Make sure you have the "On Ground" box cheked in the shadow settings. πŸ€“
                    • V Offline
                      Verrou
                      All my settings are like you say?
                      404 Not Found
                      (img186.imageshack.us)
                        boofredlay
                        Your settings are right and your shadows are falling on the ground plane correctly in that screenshot but I am confused by the preview window. What are you using to make that preview, I don't recognize it?
                        • V Offline
                          Verrou
                          IRender, and also, how do I change the corners of a rectangle/square to a radiused corner?
                            boofredlay
                            Oooooh. I know nothing about Irender, sorry. 😳 I assumed you were exporting directly from SU.
                            This Topic should help you with your second question.
                            • V Offline
                              Verrou
                              Na that's a cube, I just want to know how to do step 1 :S
                              1. Square (12x12 inches in my example) with radiused corners. (1" in my example)
                                boofredlay
                                Ah...
                                Draw your square. Get your arc tool and select the first point. Drag your pointer to the other side of the square until you see the magenta line and the text "On Edge", then click.
                                Now move your pointer towards the corner until you see the arc turn magenta again with the text "Tangent To Edge"
                                Click and you are done.
                                If you want to make sure your first point is an exact distance from the edge, use the tape measure tool and click one of the sides to start a construction line. Then before you click the second time type your distance and enter.
                                I hope this answeres your question. πŸ€“
                                  Render engines need something to cast the shadow on. You cannot just "float" in space and cast shadow on something that does not exist at all.
                                  I don't know iRender either but in other applications (like in Kerkythea) you can insert an infinite plane to work as a shadow reciever (something like the ground plane in SU). If iRender does not have this, you can still insert a really big plane whose sides are out of the view and you don't have problems with the plane changing colour slightly against the empty background.
                                  • V Offline
                                    Verrou
                                    Thanks Boofredlay works great. And i'll just export straight from SU so thanks.
                                      boofredlay
                                      Glad I could help.
