    Green Toaster's Car Sketches
    745 Posts 45 Posters 111.4k Views 45 Watching
    • ely862meE Offline
      ely862me
      at least looks like a real car,good job
      Elisei (sketchupper)
      Come and See EliseiDesign
        GreenToaster
        I'm creating a tutorial for this front end - I was almost done when I ran out of "undo".
        This front end literally takes 3 minutes, 4 with the scoop, & the tutorial might be useful for someone - it's super easy. The design is "flexible", meaning, if you set it up with layers, you can smush, stretch, pull, tug, rotate, move, et cetera, fairly easily for some decent "what if", on the fly design changes.
        BTW, does anyone know if there's a way to use the Drape tool without having to tilt the model vertical?
        Happy modeling,
        Brad
        πŸ˜„
        If you really want something you won't ever stop pursuing it.
          GreenToaster
          I posted a quick tutorial in the tutorial section . . . my tutorial isn't very good, but it might inspire someone to do something really cool . . . hope so.
          Happy modeling,
          Brad
          πŸ˜„
            GreenToaster
            . . . thought I'd revisit the 3-wheeler . . . need shock mounts on the body and some front end fairing stuff, tail lights, exhaust, door lines, & so forth, but, it's gettin' there . . .
              GreenToaster
              There's a crisis on the farm - I've gotta go do some work so no more cars for the rest of the week 😞 bummer!
              Here are a couple of sketches I started this morning . . . see ya'll next week.
              Happy Sketching,
              Brad
              πŸ˜„
                GreenToaster
                I started this one a few days ago . . . it used the technique in the tutorial I posted earlier . . . this isn't really a good example - very bland car but I couldn't resist taking just a few minutes to almost finish it . . . it's ready for a rear end, and detailing . . . I have some more ideas I've sketched up (on pencil & paper) . . . hopefully, I'll be able to model them accurately in the next few days using SketchUp . . . what else?
                Happy modeling,
                Brad
                πŸ˜„
                • ely862meE Offline
                  ely862me
                  from my oppinion this is the best
                    GreenToaster
                    I think I shortened the wheelbase a bit too much . . . I also need to rip out the windshield and add something smoother, no biggie . . . I think I'll take this one a bit further and add some details like mirrors, vents, lights, interior, the lines for doors, hood, et cetera, b/c I've never done that before and it should be a good learning experience.
                    Happy Sketching,
                    Brad
                    πŸ˜„
                      remus
                      you could jsut scale the whole thing to extend the wheelbase a bit...
                        GreenToaster
                        Thanks for the suggestion - I built in a gap so it'd be silly easy to stretch it one way or the other . . . when working in Parallel Projection (side, top, whatever) you can select with precision quickly & easily, do the drag-n-drop, then it's done.
                        I've tried stretching large sections and get frustrated with oval or elliptical shapes inside the wheel wells . . . I've even made boo-boo's and ended up with oval tires & wheels - can you imagine riding in a car had oval tires? Bumpy, for sure.
                        Happy Sketching,
                        Brad
                          remus
                          forgot about the wheels πŸ‘Š
                            SchreiberBike
                            Bad news for you about that three wheeler.
                            It's got four wheels.
                            Re. scaling the model. If you make the wheels into a component first, then you can scale the rest of the model and leave the wheels round, or you could display all the geometry again and just select the part in front of and behind the wheel and scale and/or move that.
                            Here's what I came up with from your tutorial.
                              remus
                              i tihnk the problem is more to do with the wheel arches than the wheels.
                                GreenToaster
                                True (ha), but three axles.
                                It's probably just me, but I find it challenging to model cars well - very fun, and I think I'm making a little progress (compared to the first posts I did here). I am much more confident in being able to create what I want - sketch out on paper, then model it.
                                As I've said before, some folks can play the violin well in six weeks - for some, it takes a couple of years of practice to achieve the same level. I guess it's not important how slow I am at learning this stuff - I keep going and improving little by little - that's significant to me.
                                If any of you haven't checked out the modeling videos and tutorials, there are some really good ones out there - YouTube, and several others, which I believe might be very helpful.
                                Happy Sketching,
                                Brad
                                πŸ˜„
                                  GreenToaster
                                  . . . added a few more details . . . the panel editing is super-easy-fast . . . using scale in either direction, I select sections, or sub-sections & blah, blah, blah . . . (as with the tutorial I posted a day or so ago) . . .
                                  Happy Sketching,
                                  Brad
                                  πŸ˜„
                                    SchreiberBike
                                    When I was working on my hood above, I was amazed by how dull it looked because I knew I had put lots of clever angles into it. Adding the line for the space between the hood and the fender started to show the shape better. I also changed the color of the edge of the fender and of the A pillar to a reddish brown instead of bright red. I could have gone on and put some grooves in the hood to show more. Things like that bring out the geometry in SU, similarly to the way rendering would.
                                    • ely862meE Offline
                                      ely862me
                                      the easyest way for rising the distance of weels is to rise just some segments in the midle of the car not to strech all the car
                                        Durant Hapke
                                        Brothers, and Sisters,
                                        Beauty -- this pop up batch of "cars" are all there and messing with me (in my head -- not in my hog barn -- not in my exhaust vector).
                                        You blazing batch of SU perfecters ever hear that song "Jesus built my hot rod" by Ministry?
                                        It rules, and I trust that would make a grand soundtrack for this thread of four wheeled nights on the "battle field."
                                        I'm going to have to dig out that classic, crank the stereo to pain, pour a cold one, light a camel, and have my way with some of these images.
                                        Take it rough, and feel the art.
                                        I'm feeling mad cap power action on the horizon.
                                        Durant "Yeah baby, love is a battle field" Hapke
                                          GreenToaster
                                          . . . Okay, Durant, this one was inspired by your remarks . . . I call it "Rock Crawler II" . . . it's got a long way to go . . . but the journey has begun . . .
                                          • boofredlayB Offline
                                            boofredlay
                                            You are a machine Green πŸ‘
                                            • 11
                                            • 37
                                            • 38
                                            • 9 / 38
